All Part Number Request Go Here
Old Jan 30, 2008 | 08:18 AM
  #2356
RussellM's Avatar
Plat Vendor
Originally Posted by Jameson_IXMR
RussellM that part with the 2 numbers (the trim piece for the back/rear window. I do believe that the 2 numbers are for Left and Right sides of the car.
Are you talking about the pillar trim on the interior?
Old Jan 31, 2008 | 02:16 PM
  #2357
EVO-JOE's Avatar
Let me add one.
06' Evo IX SE Oil Pressure Switch ---- Part Number 1258A003
Old Feb 1, 2008 | 06:56 AM
  #2358
Hittman's Avatar
MR973540 antenna Base
IS this this --->
the bigger portion in the yellow square sans the antenna
Old Feb 5, 2008 | 10:12 AM
  #2359
EvoDan2004's Avatar
i need the part number for the EVO RS radio panel. its black and textured like the rest of the dash. not the smooth one the 03 evos came with.
i need the hole panel. not just the part that covers the radio hole.
Old Feb 5, 2008 | 12:30 PM
  #2360
EvoDan2004's Avatar
anyone
Old Feb 5, 2008 | 03:44 PM
  #2361
RussellM's Avatar
Plat Vendor
link
http://www.mitsubishiparts.net/cart/?id=571&pn=MR633495
Old Feb 5, 2008 | 06:20 PM
  #2362
EvoDan2004's Avatar
russellm
that is the black textured one from the RS right?? i dont want the smooth grayish one that came with the 03 evo.
Old Feb 6, 2008 | 09:12 AM
  #2363
Elu's Avatar
Elu
Originally Posted by Elu
Not the cluster overlays that come in stock black, silver, or blue. The stock individual overlays that go on the tach, speed-o-meter, etc
BUMP. Need to know if its possible to order the stock overlays like in this picture from mitsubishi. https://www.evolutionm.net/forums/sh...ad.php?t=68141 without having to purchase the whole console. Preferrably for a 03-04 which doesn't have ACD.
Old Feb 6, 2008 | 11:27 AM
  #2364
RussellM's Avatar
Plat Vendor
russellm
That is for the RS
Old Feb 7, 2008 | 05:06 AM
  #2365
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Part# for the Spring/hook in the truck that helps hold-down the trunk/wing. Here is the kicker, need the one specifically associated with the RS model. Thank you!
I think they are refered to as the "trunk rods". Need the part number for RS model. Thanks as always
Old Feb 7, 2008 | 09:11 AM
  #2366
RussellM's Avatar
Plat Vendor
http://www.mitsubishiparts.net/cart/...73003+MR573004
Old Feb 10, 2008 | 03:49 PM
  #2367
Nesiop's Avatar
The rubber bushing and plastic piece that goes in the middle in each hole in the intake manifold for the injectors. THe plastic piece narrows down and goes on the outside tip of the injector then slides into the intake manifold and black rubber ring.
Whats it called/part number.
Old Feb 17, 2008 | 08:15 AM
  #2368
Fujilicious's Avatar
I searched this thread but came up empty:
Door panel clips that attach the panel to the door frame
Firewall insulation, inner and outer
Many thanks!
Old Feb 18, 2008 | 08:01 AM
  #2369
RussellM's Avatar
Plat Vendor
Many thanks!
Im only coming up with one insulator part number...perhaps they come together?
http://www.mitsubishiparts.net/cart/...45*14+MR479321
Old Feb 18, 2008 | 08:02 AM
  #2370
EvoDan2004's Avatar
russellM
i just wanted to let you know thanks for that part number. i got my part in last week and it was perfect.
