All Part Number Request Go Here
Looking for a part number for the Small dash lights that are behind the guage cluster. IE: Gas gauge and coolant temp gauge light bulbs. Some are out and I must replace them.
Need the o-ring that goes between the 2 parts of the transfer case, the main case and the short 4" piece (connected by 4 bolts facing rear) that connects to the drive shaft. here's an illustration. please let me know if i need to provide any more details. thanks!
After calling my local Mitsu dealer, they can't get the O-ring using the diagram I attached above... Received word from ShepTrans that they can't even buy that seal. John recommended gray RTV around the outside of the o-ring seal. Only a very light coat would be needed because they're two machined surfaces.
I searched the thread and couldn't find the part number anywhere. cdoes anyone know the part number for the piece that the blue and white vac lines attach to that run from the EGR. It's the piece that the nipples always break off of. Thanks!
Does anyone know the name or the part number for following part -
There is a threaded rod that extends from the top of the power steering pump. The pressure line to the steering rack bolts to this hollow threaded bolt. It is basically the fluid outlet for the power steering pump.
Does anyone have any more info on this item?
I need the all of the nuts/bolts for the front stock strut tower.....the two that connect to the firewall and all of the nuts on the strut towers......I also need a number/price on the plastic gate under the driver side dash that holds the bunch of wireharness wires up under the dash.....
