All Part Number Request Go Here
Old May 10, 2009 | 11:31 PM
  #3061
Xionicfire's Avatar
Hi im looking for the part number of the Tweeter cover plastic mesh/grill? on evo 9
Basically i replaced the original driver side pillar with a full 3 pod gauge pillar with tweeter cutout, the problem is the "tweeter cutout" does not include the original protective mesh/grill that covers the speaker hole, attempts to remove this one from the original pillar resulted in the cheap plastic mesh/grill splitting in two.
Anyone know if mitsubishi sells these tweeter covers as standalone parts and if so what would be the part number? im working on getting an image.
Usefull info:
It appears driver/passenger side grill/mesh are identical, just flipped around
It appears most normal lancers also use these cheap plastic grills
Any info locating this part number would be great.
Thank you
Old May 21, 2009 | 08:21 AM
  #3062
Bster13's Avatar
I am looking for part # and quote for the nut and bolt on the rear passenger side Lower Control Arm of my 2006 Mitsubishi Lancer Evolution IX. They are used in #12 of the diagram where the two bushings are shown on the right side:
Old May 23, 2009 | 10:18 AM
  #3063
RussellM's Avatar
Plat Vendor
LINK
http://www.mitsubishiparts.net/cart/...4*2+4113A062*2
Old May 29, 2009 | 10:00 AM
  #3064
nitai3g's Avatar
Hey everyone!
I am looking for the part number for the banjo bolt for the coolant line for evo 8 turbo.
I cant find it in the part # list.
thanks in advance!
Ty
Old May 29, 2009 | 10:28 AM
  #3065
nitai3g's Avatar
I found it!
part # MF650114 for coolant return and feed banjo bolt to evo 8 turbo
Old Jun 4, 2009 | 09:14 PM
  #3066
EVOlX's Avatar
I am looking for the rectangular plastic cover, that covers a hole in the dash in the middle of the air/defroster vent. I was running a wire and i accidentally dropped the small cover down the same hole and I can't find it. Its about 0.5''x1.5''. I believe the number is right on the bottom of the piece but I forgot to write it down. Thanks for any help.
Old Jun 5, 2009 | 09:31 PM
  #3067
Jacat's Avatar
I am looking for the part number for the 2 screws which mounts the front bumper to the chassis behind the plastic coverings of the bumper as per the circle in the picture.
Thanks in advance.
Old Jun 6, 2009 | 11:01 PM
  #3068
Russell K's Avatar
Could you please provide me the part number for the differential bolt(s) in the picture below? I need these ASAP.
Thanks!
Old Jun 7, 2009 | 01:27 PM
  #3069
EVOllie's Avatar
looking for the following part numbers:
fuel pump relay #3 (the big denso one i believe)
and the fuel pump resistor
Old Jun 8, 2009 | 11:23 AM
  #3070
~BoOsTeR~'s Avatar
I'm looking for the OEM FMIC lower mounting bolt (one that bolts the IC to the chassis) for Evo 9
Old Jun 9, 2009 | 11:15 AM
  #3071
nperkins's Avatar
Im looking for the HVAC decals for an Evo 8.
Old Jun 11, 2009 | 12:31 PM
  #3072
EvoRalph's Avatar
just did the evo ix front bumper conversion and need the part numbers for the retainer clip and cap back (snap the front bumper to the fender area) as well as the upper left and upper right reinforcement plates.
thanks in advance!
Old Jun 11, 2009 | 12:39 PM
  #3073
antilag_200's Avatar
Need the part number for the bolt and nut that hold the lower front ball joint to the knuckel ( pinch bolt and nut) .
also need the part number for the front stock sway bar end links
thanks in advance.
Old Jun 12, 2009 | 02:42 AM
  #3074
evo_skillz's Avatar
Hey russell, I bought some center caps recently from there and when I went to go have them put on, the shop told me they were the wrong ones? I don't get it.
I ordered the ones you told me to.
I can give you my order number and information but I really need these exchanged because I paid 50 dollars for these things. I would greatly appreciate it if you could help me out with this matter.
-Jonathan S.
Old Jun 13, 2009 | 10:07 AM
  #3075
grillpt's Avatar
I'm trying to find the P/N for the gasket where the j-pipe and the compressor housing meet (evo 8).
Any help would be greatly appreciated.
