All Part Number Request Go Here
Old Feb 4, 2009 | 04:11 AM
  #3001
WWEVO206's Avatar
Hey guys. I'm looking for the bracket that holds the stock air box from the bottom. I need one for my ARC super induction. It looks like this. Thanks!
Old Feb 4, 2009 | 09:50 AM
  #3002
Juan Martinez's Avatar
Originally Posted by Juan Martinez
Hello. I was wondering two things and if you have the part numbers for them and if they are the same.
Are the 02-06 ES/LS/Oz Rally E brake Cables the same as the 04-06 Ralliart?
Are the 02-06 ES/LZ/OZ Rally E brake pads the same as the 04-06 Ralliart?
Thanks
John
Any help at all?
Old Feb 6, 2009 | 09:27 PM
  #3003
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Ive never seen a heat shield under there -- the only one Ive ever seen is under the floor of the car, not up there.
A lot of people remove it. Just to clarify, it's the cover identical to the exhaust manifold cover, just covers the lower part of the turbo (turbo hotside, o2 housing). Need bolts too.
Old Feb 7, 2009 | 04:33 PM
  #3004
DOUGLAS's Avatar
Can I get the numbers for a 2003 Evo cam position sensor and the front windshield washer pump(DENSO)......the link given to me last time for the pump was the same price and part number for the front and rear and all I will be needing is the pump...thanks
Old Feb 8, 2009 | 10:55 AM
  #3005
EvowagonIX's Avatar
nice info
Old Feb 8, 2009 | 08:13 PM
  #3006
hang187's Avatar
i need part # for battery tie downs. I lost one rod. probably gonna have to get the whole thing. (2 rods & clamp) thanks!
Old Feb 9, 2009 | 06:28 AM
  #3007
LetsGo82nd's Avatar
Hardware to Re attach Wing
I am looking for the following part numbers to re attach my factory wing on an EVO VIII.
Gasket, double sided tape, bolts, nuts and caps. Thanks.
File Type: pdf
Old Feb 11, 2009 | 05:47 PM
  #3008
Nasty Evolution's Avatar
I am in search of part numbers for the gears in the VIII 5 speed tranny.
4TH SPEED GEAR
gear has the mating teeth for the syncros/SYNCHRONIZER SLEEVES
Also need part numbers for all 3 SYNCHRONIZER SLEEVES
Also looking for part numbers for all of the syncros if possible.
I'm trying to figure out how to post a pic from the service manual, it's a pdf.
Old Feb 11, 2009 | 07:21 PM
  #3009
Is this thing broken?
Old Feb 14, 2009 | 12:45 PM
  #3010
Jackyll's Avatar
I searched for this last month when i needed it but didn't find it so i'm going to post it, sorry if it's already on here. FYI, it took mitsu a month to get it... and that's with it coming 2 week early.
Resistor pack for injectors. PN: MR561990. Here's some pics.
Old Feb 18, 2009 | 12:39 AM
  #3011
5k6's Avatar
5k6
Part numbers for 2,3,4,5,6,8. See image attached
Old Feb 18, 2009 | 01:32 PM
  #3012
not2slo128's Avatar
Need that little plastic red lens on the rear bumper of the Evo 9. What's the number?
Old Feb 18, 2009 | 01:33 PM
  #3013
not2slo128's Avatar
There are two total - one on the left one on the right. They light up when you turn the lights on,.
cheers.
Old Feb 21, 2009 | 10:21 AM
  #3014
RussellM's Avatar
Plat Vendor
LINK
http://www.mitsubishiparts.net/cart/...&pn=MN161534*2
Old Feb 21, 2009 | 11:33 AM
  #3015
Thanks
John
