All Part Number Request Go Here
Old Aug 8, 2010 | 02:11 PM
  #3346
lp_ceo's Avatar
evo 8
5 spd shifter base bushings and bolts
mr 6 spd trans temp sensor
acc. belt tensioner
front seat nuts and bolts
Old Aug 12, 2010 | 12:05 PM
  #3347
Chamo4u2's Avatar
need help with this part number...
first of all what is this part circled in red? I tried looking for a evo 8 trans diagram but was unlucky so I figure I'd give this a shot (it's part of my trans/transcase but it keeps getting stuck not engaging all the way in all the time...any way to fix this?? Greatly appreciated in advance...
Old Aug 12, 2010 | 10:50 PM
  #3348
lp_ceo's Avatar
any pn# for the tc banjo bolt and washer ?
Old Aug 13, 2010 | 09:09 AM
  #3349
Chamo4u2's Avatar
anyone?? does anyone know what that part is?? I don't even need a part number even guidance in the right direction would help....
Old Aug 13, 2010 | 03:05 PM
  #3350
w evo's Avatar
anyone know the part number for the clip that holds the throttle position sensor to the electrical plug? It is a three sided metal retaining clip. Any help would be greatly appreciated!
Old Aug 15, 2010 | 07:48 AM
  #3351
cheb evo's Avatar
Does anyone have the part number for the injector resistor box with harness? Thanks.
Old Aug 16, 2010 | 05:36 PM
  #3352
blown1's Avatar
evoix mas screw
does anyone know if there is a seperate part number for the cylinder/screw thing thats under the silicone at the bottom of the mas air flow unit or is it a part of the mas. I guess you could call it the mas air adjustment screw like this one from a 2g mas. Its that little black cylinder at the bottom of the picture that goes up into the mas air sensor unit.
Thanks
Old Aug 22, 2010 | 09:15 AM
  #3353
Jihun's Avatar
Wow! This is really good information!!
Old Aug 23, 2010 | 02:09 PM
  #3354
asdfasdf128's Avatar
need part # for the piece that fills the two holes in the bumper that I've boxed.
Thanks!
Old Aug 23, 2010 | 02:12 PM
  #3355
repost fail
Old Aug 25, 2010 | 07:58 AM
  #3356
Paulito's Avatar
im looking for the panel below the glove box that covers the harness. i cant find a number nor can the dealer. i never had it on my 06 but my friends 05 ssl did. any help?
Old Aug 26, 2010 | 10:56 AM
  #3357
RussellM's Avatar
Plat Vendor
I dont see anything separate from the dash assy in that area.
Can you email me a picture of the area and possibly a picture of what it supposed to be (if you can find one)?
(attach the image(s))
russellm@brucetitus.com
Old Aug 31, 2010 | 05:55 AM
  #3358
thermaldynamics's Avatar
I am in need of the mitsubishi part number for the transmission mainshaft (output) outer bearing (driver side). This is the bearing with the snap ring groove.
Number on the bearing outer race: NTN SC06C44
Number on the cage seal: SC06C44LA
If Mitsubishi does not supply this, does anyone have a source?
Old Sep 1, 2010 | 08:29 PM
  #3359
B-rent's Avatar
Front Fender Liner
hello, I drive a 2003GSR and i need to replace the front driver side fender liner.
What are the part numbers for the,
-fender liner (pic 1)
- another smaller liner (pic 2)
- fender plastic hardware kit for both front driver and passenger (pic 3)
Attached Thumbnails All Part Number Request Go Here-photo09011727.jpg   All Part Number Request Go Here-photo09011728.jpg   All Part Number Request Go Here-photo09011728_1.jpg
Old Sep 4, 2010 | 11:47 AM
  #3360
Jihun's Avatar
Is there a code for rain guards?
