All Part Number Request Go Here
Old Dec 21, 2010 | 06:39 PM
  #3436
850RCT9A's Avatar
whats the part number to the little black washers for the valve cover bolts??
Old Dec 22, 2010 | 04:21 AM
  #3437
sk82712's Avatar
Part number and a vendor that sells it for:
'Fuel pump and gauge assembly' and
the accessory belt tensioner (it snapped while I was working). Its right next to the oil filter.
-Adam
Old Dec 24, 2010 | 01:02 PM
  #3438
EvoooB's Avatar
Need some help guys.I dropped my tranny and t-case to do a clutch job and would like to replace some seals/o-rings while it's down. Can anyone give me the part numbers to the listed reference numbers below from the picture, and also verify if these are correct for my vehilce: 2006 IX 5sp ACD/ Thanks!
30146- Quantity 2
30289P- Quantity 2
30145P- Quantity 2
Originally Posted by tscompusa
Old Dec 27, 2010 | 01:33 PM
  #3439
850RCT9A's Avatar
need part numbers for the 6 bolts holding the transfer case to the tranny..thanks
Old Dec 27, 2010 | 02:56 PM
  #3440
dji's Avatar
dji
I need the part number for the 30289S, 30289P and the 30146.
Thanks
JF
Timing tools: http://www.jayracing.com/index.php?m...roducts_id=214
balance shaft tensioner pulley: i think this is what you meant? MD352473
tell me the reference number and ill get you the part number.
Old Dec 27, 2010 | 03:19 PM
  #3441
tscompusa2's Avatar
Originally Posted by dji
i need the part number for the 30289s, 30289p and the 30146.
Thanks
jf
30289s = md743612
30289p = md727944
30146 = mr980100
Old Dec 27, 2010 | 03:22 PM
  #3442
BEISSEN's Avatar
I need a part number for the IAC Motor, I am throwing code PO505 & PO170 and the tuner thinks its the IAC motor or throttle body.
Old Dec 27, 2010 | 04:26 PM
  #3443
EvoooB's Avatar
Bump! Still need some help guys. From the illustration above, I need a part number for reference 30145P. Thanks
Old Dec 27, 2010 | 05:11 PM
  #3444
mctenold's Avatar
Anyone know the injector resistor part number? Mine has rusted and a wire has broken. I need a replacement.
Image for illustration:
Old Dec 29, 2010 | 12:43 PM
  #3445
EvoooB's Avatar
Need the part number for the notorious leaking grommet on the inside of the front driver side fender. Its about 5" tall and is oval and can been seen in this thread.... https://www.evolutionm.net/forums/in...s-how-fix.html
The wiring for the front fuse box in the engine bay runs through this grommet if that helps at all.
Old Dec 29, 2010 | 05:16 PM
  #3446
Buch's Avatar
Anyone know the part # for the jack? I just found out mine is not in my trunk by my spare tire
Old Dec 29, 2010 | 06:14 PM
  #3447
I4UnderPressure's Avatar
I'll sell you mine. Its out of the car.
Old Dec 29, 2010 | 06:23 PM
  #3448
Buch's Avatar
PMed
Old Dec 30, 2010 | 11:49 AM
  #3449
Sil'vr-Boi6's Avatar
My Right Arm is stronger than my left arm
I accidently broke the door handle of the passenger storage compartment .I did not see a part number for the passenger storage box below passenger air bag. Can somebody direct me or enlight me whether a lancer oz or a lancer door latch will fit a evo. Thanks
Old Dec 30, 2010 | 09:24 PM
  #3450
BEISSEN's Avatar
Heres the Part number for the IAC motor/Solonoid 1450A069 cost was 470.XX but I got it at wholesale since I told the Dealer I could get it from Mitsubishiparts.net for 312.00 they sold it to me for 315.00 plus tax and it was 329.24 total.
