All Part Number Request Go Here
Old Dec 7, 2011 | 08:10 PM
  #3646
88888's Avatar
looking for bolts that hold front and rear struts to the chassis.
i believe 2 bolts in front 3 in rear
bolts and nuts
Old Dec 8, 2011 | 01:05 AM
  #3647
Charles12345's Avatar
what about the bolts that hold the cam gear cover, i don't have a a part no.
__________________
Local to DC, VA, MD?
Old Dec 10, 2011 | 06:26 PM
  #3648
JPooah's Avatar
part number request for an evo 9 GSR Lip part
air dam skirt panel as seen here in the manual
Very greatly appreciated please PM
Old Dec 11, 2011 | 07:19 PM
  #3649
therunningskier's Avatar
I need the part #'s for the tie rod end piece and the lca end piece and boots for both:
Old Dec 12, 2011 | 04:02 PM
  #3650
88888's Avatar
bolts and nuts
bump
Old Dec 12, 2011 | 11:43 PM
  #3651
Mary58712's Avatar
i need the following parts:
trunk liner (the full trunk thingy)
the black plastic piece at the end of the trunk
coin box
and that it is for now
Old Dec 16, 2011 | 01:41 PM
  #3652
kidkayos's Avatar
Does anybody happen to know the part numbers for the outer weatherstrips (the long strip that goes from the windshield that goes all the way back to the trunk)?
Old Dec 18, 2011 | 04:57 PM
  #3653
blacktab420's Avatar
Rear exterior door handle assembly ???
Mine is broken . Color is GG and it is written MR526131 on it, but when i search with that number, i found nothing at all anywhere ...
Old Dec 18, 2011 | 05:06 PM
  #3654
sorry, double post .
Old Dec 18, 2011 | 11:40 PM
  #3655
Linda7463's Avatar
the magnetic drain plugs from the evo.. i want to use the tranny ones on my RA.. is the oil one magnetic too?
Old Dec 22, 2011 | 07:05 PM
  #3656
whitersevo's Avatar
part number for spoiler trunk bolts.. I need the bolt and nut part number... please
Old Dec 28, 2011 | 05:41 AM
  #3657
grillpt's Avatar
Can someone confirm this is the correct p/n for the input shaft bearing?
MD771359
Old Dec 28, 2011 | 08:54 AM
  #3658
SloRice's Avatar
I'm looking for the metal U-shaped retaining clips that hold the wiring harness plugs on the throttle body, MAP sensor and that emissions sensor on the passenger side of the intake manifold.
It looks like you could make these out of paper clips!
Thanks!
Old Dec 30, 2011 | 06:52 AM
  #3659
dimviii's Avatar
which is the part number for the evo 9 mr headlights(both) with fog light inside?
thanks in advance.
Old Dec 30, 2011 | 07:47 AM
  #3660
SloRice's Avatar
soooo, just curious if anyone actually answers these requests??
