All Part Number Request Go Here
Old Feb 20, 2012 | 07:19 AM
  #3691
nollij's Avatar
Anyone know the part numbers for the A/C system in a Evo 9?
Old Feb 20, 2012 | 08:53 PM
  #3692
Evo9"Miss Rose"'s Avatar
can i get the part # for Evo IX MR "input shaft bearing"
Old Feb 23, 2012 | 08:02 PM
  #3693
boostedwrx's Avatar
Oil pan bolts part #? Before I call the dealer thought I would check..
Old Feb 24, 2012 | 04:05 AM
  #3694
killercd4G63's Avatar
Veteran: Army
2004 Evo SSL
Alternator full piece part # ?
Old Feb 25, 2012 | 10:05 AM
  #3695
boostedwrx's Avatar
Originally Posted by killercd4G63
2004 Evo SSL
MD366831
http://www.mitsubishiparts.net/catalog/?section=1072
Old Feb 25, 2012 | 11:54 AM
  #3696
boostedwrx's Avatar
MF140201 x 2
MD097012 x 17
Finally installed Mitsu ASA and it's pretty sweet
Old Feb 25, 2012 | 01:31 PM
  #3697
Veteran: Army
Thanks so much!!!
Old Feb 25, 2012 | 02:14 PM
  #3698
boostedwrx's Avatar
Originally Posted by anthonyrb98
does nobody know the part number for the brass plug?????
If you havent found it yet, lemme know what part on the clutch housing you think it is and I'll look up the part #
Old Mar 5, 2012 | 06:31 AM
  #3699
144mph's Avatar
Oil cooler line banjo fitting crush washers. Part pictured here as 04328.
Could also use the torque spec if anyone has that available as well. Thanks!
Old Mar 5, 2012 | 08:18 AM
  #3700
boostedwrx's Avatar
04328 = MR464563 and it appears you need Qty of 8 for the complete job.
Good luck!
Old Mar 6, 2012 | 05:26 PM
  #3701
dillonb's Avatar
part number for the bolts that go from the return line to the turbo all i could find was the return line to the pan are they the same bolts?
Old Mar 6, 2012 | 09:22 PM
  #3702
terfer's Avatar
Part No. for the metal bracket under the headlight that holds the bumper in place. TIA.
Old Mar 7, 2012 | 08:23 AM
  #3703
boostedwrx's Avatar
^I'll look those part #'s up when I get to my PC with ASA if you don't get them answered before then.
Old Mar 11, 2012 | 08:45 AM
  #3704
dillonb's Avatar
still nothing?
Old Mar 11, 2012 | 09:18 AM
  #3705
nytalonTSi's Avatar
mf241225.
