All Part Number Request Go Here
Old Nov 8, 2006 | 08:11 PM
  #1396
AutoKA24DE's Avatar
I need the plastic trim piece by the accelerator pedal. For some reason the prior owners discarded it.
thanks!
Old Nov 9, 2006 | 09:03 AM
  #1397
BIGBADRS9's Avatar
anyone have the part number for the RS side mirrors. the unpainted ones. And will fit a RS trunk bar fit the SE, do i have to drill holes?
thanks
Old Nov 10, 2006 | 12:48 PM
  #1398
Spins4's Avatar
Hey guys/gals, just wanted to give everyone a heads up, I JUST got my part catalogs in for EVO/Lancer 2-7's. Now, some things I have already been told I cant' order, but some stuff I can. But hey, at least I can get part numbers.
P.S. No, I can not get EVO VII front bumpers, that was the first thing I tried
Old Nov 10, 2006 | 01:55 PM
  #1399
WarmPepsi's Avatar
i tried to order a spare set of pins for both the front and rear brembros (seeing that knowing me, i'll probably loose/kill one) but that was backordered past infinity.
any luck on you getting them?
Old Nov 10, 2006 | 02:15 PM
  #1400
Spins4's Avatar
I have 3 left of the fronts...and about 24 of the rears.
Don't ask, Mitsu kind of dropped the ball when I ordered them originally
Old Nov 10, 2006 | 02:21 PM
  #1401
WarmPepsi's Avatar
lol!
You do paypal? send me an invoice thing for 2 of each. (if not, just send pm)
Old Nov 11, 2006 | 04:47 PM
  #1402
Peke's Avatar
Doesn't anyone know what is USDM head and taillight part numbers?
Old Nov 13, 2006 | 06:33 AM
  #1403
Spins4's Avatar
Wish I did
Old Nov 14, 2006 | 05:47 AM
  #1404
EvoBig16G's Avatar
anybody know the part number to the factory boost solenoid? also called Turbocharger wastegate solenoid.
located in the lower right hand corner. thanks
Old Nov 14, 2006 | 10:19 AM
  #1405
Spins4's Avatar
Originally Posted by evobig16g
anybody know the part number to the factory boost solenoid? Also called turbocharger wastegate solenoid.
Located in the lower right hand corner. Thanks
mn143213
Old Nov 14, 2006 | 06:26 PM
  #1406
MSTR MR9's Avatar
Doing a 6 speed to 5 speed conversion and need part numbers for. 5 speed tranny mount, shifter cables, shifter base, shifter and harness that connects to speed sensor and reverse sensor. THanks Alot.
Old Nov 15, 2006 | 07:34 AM
  #1407
Spins4's Avatar
Tranny Mount: MR491558
Cables: MN107670
Shifter Base: MR246297
Shifter: MN168249
Harness (looking like only way is front harness): 8541A010
Old Nov 15, 2006 | 08:31 AM
  #1408
MSTR MR9's Avatar
Would you possibly have these parts in stock, if so i will buy these parts today. Also can you tell me how much for all of them. Thanks Alot. I will probly call your shop later on today, my name is Greg. also thanks alot for your help.
Old Nov 15, 2006 | 08:34 AM
  #1409
MSTR MR9's Avatar
I keep forgetting to ask do the shifter cables come complete, with all the bushings and everything you need to use them right out the box. Thanks
Old Nov 15, 2006 | 09:17 AM
  #1410
Spins4's Avatar
Unfortunately I do not have any of this in stock, but at the most takes me a couple of days to get (unless on back order). If you like, just give me a call I can help you out. Plus I want to talk to you about the harness. Lastly, yes, the cables have the bushings. Thanks!
Oh, if you call and I happen to be at lunch, drop me a pm or leave a number and I will deff get back to you. Thanks again!
