my service engine soon light just came on
Old Mar 13, 2005 | 04:15 PM
djmikeymike's Avatar
what up all........my service engine soon light came on on my way home....what do i do? everything seams ok...i got on it once and i didn't feel any loss of power......need some help guys
Old Mar 13, 2005 | 04:24 PM
04Evo8RS's Avatar
mine does it all the time because of my intake it gets annoying disconnect your negative battery cable and then like 5 minutes later reconnect it your problem should be solved but it will proly come back......
Old Mar 13, 2005 | 04:29 PM
ct9a gsr's Avatar
Goto your local automotive shop like Autozone, Pep Boys, etc... and have them pull the CEL code on their scanner and come back and tell us what it is... or do a search with the CEL code to find lots of info. Without the CEL code, we can't help you...
Also, don't reset the light until you get the CEL code... then reset the battery (neg. terminal) or unplug/replug the ecu to get rid of the light.
Old Mar 13, 2005 | 04:47 PM
i just got back from autozone and they where closed......I'm going to call the shop i get my work done at tom and see if they can read the code.......is it ok to drive???
Old Mar 13, 2005 | 05:03 PM
AlwaysinBoost's Avatar
go back to autozone when they open and get it scanned for free or if your unmodded take it straight to the stealership. chances are its a random cylinder misfire P0300 code...
Old Mar 13, 2005 | 05:20 PM
rn's Avatar
rn
check ur gas cap, make sure its properly close (click 3 time or more) if its not properly close ur service engine soon light will turn on.it happend to me, this stupid gas man didnt close it properly! close it and ur onboard diagnostic will correct d problem, light will turn off by itself.(read ur car manual it helps!)
Old Mar 13, 2005 | 05:25 PM
ct9a gsr's Avatar
Your vehice *should* be fine to drive normally if you're not experiencing any symptoms of any type of problem... however, it's upto your descretion.
As someone stated, if you're 100% stock, get the dealership to look at it... if you're mod'd, goto your local automotive store and get the CEL code... just don't reset it until you know what the code is.
Old Mar 13, 2005 | 08:07 PM
thank you everyone....going to autozone tom after work
Old Mar 14, 2005 | 12:33 PM
ok just got back from autozone......got a code P0420....
Old Mar 14, 2005 | 12:36 PM
03EvoVIII's Avatar
Are you running catless? From the code, I would imagine you are. Search for that code on here and there will be many different fixes for you to try....
Old Mar 14, 2005 | 12:37 PM
justchil's Avatar
I love search!
Old Mar 14, 2005 | 12:48 PM
just did the search.......i have a UR high flow cat.....guess I'm going to try one of the fixes
Old Mar 14, 2005 | 01:35 PM
bigjhoney's Avatar
Use the fix with the 2 spark plug foulers, from what i heard that one works best.
Old Mar 15, 2005 | 01:42 PM
an0ther's Avatar
i have cat del pipe and did the 2 spark plug fouler. Took a total of 20 min to drill them out and install them and have not thrown a code in over 5k miles. I did have to beat my floorboard up a little bit to get the foulers to fit because of the location of my sensor on turboXS catback.
nguyent10
Sep 23, 2011 08:32 AM
GBAILEY472
Jan 15, 2010 09:20 AM
cij911
Nov 22, 2009 12:01 PM
davidmitsusrock
Lancer Engine Tech
15
Nov 20, 2007 04:18 PM
vonserb
43
Oct 20, 2005 01:00 PM
