Underhood Bushings and Weighted Shiftknob
Old May 1, 2005 | 02:39 PM
ancker's Avatar
I got my Greddy weighted shiftknob and installed my brass underhood shifter cable bushings last night.
I immediately felt improved feel when shifting. I'm very happy with the result of the cheap simple mod. I might do the in-car bushings sometime as well, but since you have to take the center console off, I'll wait unil I have another reason, so I can do it all at once.
I bought both from lancershop.com, that place has become my #1 place to throw money lately.
/ancker
Old May 1, 2005 | 03:14 PM
TalonRcR's Avatar
/ancker
Just be careful the bushings have been known to seize up. Causing your shifter to not move correctly. Have seen it personally twice now.
Chris
Old May 1, 2005 | 06:02 PM
LanEvoDemon's Avatar
Chris
I installed the shifter bushings and it felt fine, but I noticed after I installed the shift cable bushings, that it would seize up every once in a while and wouldn't shift properly. I just got the Greddy CW knob from logicperformance and it seemed to fix any problems with the shady shifting. Definetly balanced everything out. Recommend this combo to anyone!
Old May 3, 2005 | 01:42 PM
rsboy's Avatar
I used the Kartboy underhood bushings... made out of hard plastic, which might be better since i heard the brass ones seized up on some people. I used some Ebay brass base bushings and bought a shortshifter from Ebay, also...same "quality" as the Lancershop ones... they all work pretty well together.
Old May 3, 2005 | 01:45 PM
EV0lut10n_8's Avatar
Chris
Not sure how these under the hood bushings can "Seize" up. When I installed mine there is no real spinning action being done by these bushings. Am I missing something? Seems like they are just a replacement to negate the flex of the stock bushings. BTW made a big diff in my shifting as well.
Old May 3, 2005 | 02:01 PM
SillySpheres's Avatar
I have underhood and shifter bushings and had a problem about a month and a half ago when a joint near the underhood bushings seized and I needed 2 hands to shift the car into reverse. The dealer took care of it under warranty by removing it and relubracating everything.
Old May 3, 2005 | 02:08 PM
Jakeg97's Avatar
/ancker
nice
was mine 2
Old May 3, 2005 | 02:13 PM
dividedsky's Avatar
I've got the Kartboy shifter bushings and the "under hood" linkage bushings. I had done some reading around here about the seizing problems and asked Tom at Kartboy about it; He said he had never heard of it with his bushings, but if it made me more comfortable I could use some white lithum grease to lubriate them during the install. I've had them in for about three months now, also with the Greddy Counterweight knob, no problems what so ever, and greatly improved shifting feel. (Although it did take some finagaling to get the under shifter bushings in, as they were a little to big to sit in the shifter carrige holes correctly.)
Anyone tried the upgraded clutch cables? Does it provide a noticable difference in the clutch feel?
ancker
10
May 19, 2007 04:57 PM
Grey Razor
17
Nov 18, 2006 05:22 PM
ancker
31
Sep 17, 2005 08:45 AM
dbdude
Sep 11, 2005 08:13 PM
ancker
15
Apr 29, 2005 02:15 AM
