Where to buy just a lower IC pipe?
Old May 20, 2005 | 08:23 AM
Ludikraut's Avatar
AMS.
l8r)
Old May 20, 2005 | 09:04 AM
w_tomas's Avatar
I got the FG lower intercooler pipe and am very happy with it. For the price($145 shipped), it can't be beat. It is a solid piece. I can vouch for Jimmy at Fighters Garage, his customer service is top notch. He even said if you are not satisfied with it he will refund your money. Boost response is a better after eliminating that long piece of flex hose.
Old May 20, 2005 | 01:03 PM
trinydex's Avatar
Originally Posted by FightersGarage
The current lower pipe is a completely different design and is welded by a professional. I should be receiving them back from the powdercoater today or early next week. I will post a pic of the final product. The pics that are up now are of the pipe with high temp paint so that we could test fit the pipe and drive it around for the results. The powdercoating is a much more durable finish that is pretty much bulletproof.
i'm all eyes (ears) whatever...
Old May 22, 2005 | 08:41 AM
Lancerlot215's Avatar
Just ordered mine from FG. Anyone looking for a lower intercooler pipe should at the very least check them out.
Old May 22, 2005 | 09:15 AM
trinydex's Avatar
anyone else have pics of the final product?
Old May 22, 2005 | 09:18 AM
zupber4930's Avatar
Go AMS...they have SUCH sweet parts and it's all beautifully made. Martin takes his time creating these items and puts a lot of attention into how it performs on our cars...
Check out thier website and give them a call...they are the best in the business...
http://www.automotosports.com
Old May 22, 2005 | 09:29 AM
DEV0LUTI0N's Avatar
I like the FightersGarage lower I/C pipe. I will definitely be getting one of these. If someone knows who I can speak with directly at FG to get some custom work done, please PM me. Thanks.
Old May 22, 2005 | 09:49 AM
taenaive's Avatar
looks like Fighter garage is the winner. price/preformance .
Old May 22, 2005 | 10:17 AM
Ludikraut's Avatar
Hate to say it, but on the fighter garage lower IC. The overall design is good, but look at the lip. Looks like someone just welded a seam onto the end of the pipe, that pipe does not have a proper bead. As a result I would very much question how well it would hold up in high boost situations. Also, nowhere does it say whether it is steel or aluminum
l8r)
Old May 22, 2005 | 10:32 AM
bigjhoney's Avatar
I can get them for same price maybe cheaper than fb( almost positive its aluminum, will double check). They are custom made by a professional evo tuner, awesome quality. PM if you are interested and ill give you more details and pictures once I get it installed on my car.
Old May 22, 2005 | 09:02 PM
w_tomas's Avatar
I've had the FG licp pipe on for 2 weeks now with no problems. The pipe has not blown off yet. IMO, the AMS pipe is beautiful. Everything AMS makes is a work of art. I am going to be upgrading my turbo in the future, so it will most likely make my stock/FG licp obsolete since most turbo kits come with a new licp. I did however want to get a better piece in to bridge the gap between my current setup and a turbo upgrade. For the price, you can't beat the Fighters Garage pipe. It's cheap, effective and no one will ever see it. Good luck to all looking for a good licp.
Old May 22, 2005 | 09:14 PM
evo81's Avatar
fighter garage looks good.the price is right also.i can't wait to see there intake and upper ic pipe.
Old May 22, 2005 | 09:17 PM
Derek888's Avatar
the AMS pipe also looks like it necks down at one point.... any idea what size it necks down to?
Old May 22, 2005 | 09:37 PM
Hiboost's Avatar
I can confirm that all that the bead really does is prevent the band clamp from forcing it's way off under boost. The seal is created under the clamp area not the edge of the pipe to the hose. Just 3 slightly raised spot welds around the pipe will keep it from slipping off.
Old May 22, 2005 | 11:45 PM
EVOLUTIONIZE's Avatar
If your clamp is tight enough theres no way your going to blow it off, The weld is doing a good enough job, if you want a pretty Pipe go with AMS, i wonder how your going to show off your lower pipe, let me know.. I havent had a single problem with the fighters-garage lower pipe, and it got the job done.. for half the price. I believe $225 for a lowerpipe is definitely exaggerated. Good luck on your quest.
