Beating a dead horse, Greddy type s ?
Old May 26, 2005 | 07:18 AM
Willie Dynamite's Avatar
Alright I have had my Greddy installed for a while now and it works fine. However I can have it make two different sounds. I would assume that one sound is caused by it being either too tight or too soft. It can makes a whoosh squeak sound or it can make a chute chute sound. So does the chute chute sound come from it being too tight or is the whoosh squeak sound from it being too soft? Any input would be great, thanks.
Old May 26, 2005 | 07:21 AM
temps's Avatar
rofl chute chute sound. cute post. just commenting, nothng helpful
Old May 26, 2005 | 09:07 AM
4ringturncoat's Avatar
Chute chute is compressor surge, if you really like your turbo it is best to not make it do that. It will hold boost better with higher spring tension but it will also be more likly to surge. Mine does it most in 4th or 5th with light (under 5 lbs) of boost and a slow release oft he throttle, if I back of quick I never get it.
Old May 26, 2005 | 09:23 AM
That's what I thought. Thanks
Old May 26, 2005 | 10:41 AM
whoosh+tweet is good, chute chute bad. I have played with spring tension and even running a single small spring with 4 turns on the adjuster and the car still ran within a few 100th's of a second of having it cranked down and the heavy spring. I run the small spring in the winter (valve seems tighter wehn it is cold out) and the havey spring 1 turn in for the summer. If I try really hard it will surge only in 5th when letting off the throttle if I am jsut getting into the boost.
Old May 26, 2005 | 10:44 AM
Jakeg97's Avatar
'chute chute' sounds like the bov is installed backwards
https://www.evolutionm.net/forums/sh...d.php?t=113527
Old May 26, 2005 | 06:06 PM
It's in correctly.
Old May 26, 2005 | 06:09 PM
EvO6-RS2's Avatar
whoosh+tweet is good...i agree
Old May 27, 2005 | 11:26 AM
CICreations's Avatar
Is this the sound you're car's making??
http://www.shelbygroup.com/media/wowo.wmv
Sorry, I couldn't resist..
Old May 27, 2005 | 08:12 PM
^ That's Hot!
ToMuchBoost
10
Sep 18, 2007 10:22 AM
B4IFLY
Aug 6, 2006 08:13 PM
Chute Boxe
Lancer Engine Tech
21
May 15, 2006 01:42 PM
RogueSTi
Oct 21, 2004 10:56 PM
