A/C makes car almost stall sometimes
Old Jun 6, 2005 | 05:15 PM
RXWarrior2's Avatar
Hmm, I have never had the car stall or about to stall with
the A/C on. It's stock and has 12,000 miles on it. Of course
it loses a little power like all cars as you accelerate with the
A/C on.
Evo-VIII's Avatar
ya hit the gas to prevent that stalling,thats why i have to rev it cause if not rpm is dipping down to 400.
Old Jun 6, 2005 | 05:26 PM
bigjhoney's Avatar
I had the same issures until I installed my jdm mr valve saterday, drove to work and back with a/c, idle was a bit rougher, but nothing like it was) dropping down to 500 and back).
Old Jun 4, 2009 | 11:16 AM
ekizenbe's Avatar
hate to bring this back up but, did anyone ever find why our cars try to or do stall when the a/c is on?? I would rather not just raise my idle up to compensate. I would love to fix what is causing the problem.
Old Jun 4, 2009 | 07:08 PM
RunRunRun's Avatar
Originally Posted by TheBigLubinsky
How do I raise the idel?
Originally Posted by sonics36
hit the gas
I lol'd so hard
Old Jun 4, 2009 | 07:13 PM
evo unknown's Avatar
When my a/c is on when I am idling, my rpms actually increase.
Old Jun 4, 2009 | 07:21 PM
LANCEREvo9MR's Avatar
same here
Old Jun 4, 2009 | 07:37 PM
SaTa's Avatar
I guess the idle is "rough" because when the a/c is on, the load on the engine changes with the compressor kicking in and out. When you push the a/c button in the car there is an electric clutch on the compressor wheel that engages and disengages when the gases need to be moved. When engaged, load increases and the rpms dip. The ecu should compensate and thats why some cars the rpm go up a little. For our cars it doesnt all the time. I know mine the rpm goes down to like 500 and quick blip on the throttle should rectify it. Dont think there is anything we can do about it, cause i dont think you can tune for when the a/c is on. just my $.02
Old Jun 4, 2009 | 10:30 PM
Clutchdc5's Avatar
i though tit was just me, my car stalls a lot with A/C on, esp when i come to a rolling stop with clutch down. i just learned to drive differnt
Old Jun 5, 2009 | 01:34 AM
MR. EVO MR's Avatar
For almost a year now I don't have ac anymore, mainly because of that reason whenever at a stop light with ac on I would have I play with the gas to keep her from stalling, one day my ac stopped blowing cold air and I took her to the dealer; it was august at that time. The dealer had to order a part, don't remember what part, I never went back because she drives better now with no ac.
Old Jun 5, 2009 | 01:38 AM
MR. EVO MR's Avatar
Oh another trick is turn off the ac when at lights or when stopping, when you take off turn it back on, don't raise the rpm thing
Old Jun 5, 2009 | 05:00 AM
evoamy's Avatar
We swapped out my boost controller (changed to a hallman) and BOV (forge now) seemed to fix issue of stalling (once it stalled in a slow turn with ac on eeeek)
Old Jun 5, 2009 | 05:18 AM
LI Pinky's Avatar
If your tuned on a standalone, then that could be why...
Old Jun 5, 2009 | 01:03 PM
phenem's Avatar
All A/C problems can be fixed with a correct tune on the car. I had problems for years and fixed it by setting my B.I.S.S. idle screw and correcting my idle maps. Once that was done I have no issues at all with my A/C!
Take a look at your idle maps and set your B.I.S.S. idle screw by putting the car into SAS mode in EVOScan.
Old Jun 5, 2009 | 01:21 PM
Smike's Avatar
There is a idle control bleeder on the back side of the throttle body. Using a short philips screw driver slowly tune it with the a/c on and off to the point that the RPMs do not suffer too much with the a/c on.
