Help! Why is my oil light coming on?
Old Jun 12, 2005 | 10:53 AM
quiksilverevo26's Avatar
4400 miles??? Have mitsubishi worry about it
Old Jun 12, 2005 | 01:38 PM
Aikido's Avatar
i had this on my 05 also, turned out that my # 1 bearing spun, i had like 3K and some change miles, Dealer had to put new engine and turbo in.
Old Jun 12, 2005 | 03:49 PM
JOHNNY EVO's Avatar
It only Does it when it's warm. I adjusted the idle so it does happen @ 900-1000rpms. Man I hope nothing is wrong.
Old Jun 12, 2005 | 04:57 PM
apexernsx's Avatar
Have a mechanic hook up a mechanical guage and check it hot at higher rpms to see what your oil pressure is before you do anything else
Old Jun 17, 2005 | 10:08 PM
JOHNNY EVO's Avatar
Well I hooked up a mechanical gauge to the plugs on top of the Oil Filter. The sameplace where people stick their oil pressure senders for aftermarket gauges. It read 20psi @ idle with the oil light on. Oil is filled up. I could not find the stock oil pressure sender so I can check it in that location also. So far nothing to really worry about yet.
Old Jul 30, 2005 | 09:36 PM
fitch's Avatar
i have a problem with my oil light flashing on and off... after my tune... could it be a hose on the oil pressure switch???
Old Jul 31, 2005 | 07:18 AM
mr0072003's Avatar
Dam I need an oil pressure gauge so I know what normal is.......I wonder if Mitsu will sell just the Iol pressure gauge and in White Face...
Old Jul 31, 2005 | 12:19 PM
MitsuJoe's Avatar
Do you have any CEL? I would let the dealer sort it out, this is not normal.
onlynamenotused
15
Oct 13, 2018 11:48 AM
tonydith
Nov 6, 2016 08:46 PM
fvaldes
Aug 22, 2014 11:13 PM
DevilDuck
10
May 23, 2010 03:35 PM
Fifty
Feb 12, 2010 02:39 PM
