HID's not high enough?
Old Jun 18, 2005 | 03:22 PM
JSYEVO's Avatar
ok, well you know how you can adjust the headlights? well, i put the all the way up, and i still dont think its high enough, like i cant see that far ahead of me, they're aimed too low! is there any way i can make it so its higher?
Old Jun 18, 2005 | 03:24 PM
alan678's Avatar
instrested here as well...
Old Jun 18, 2005 | 03:27 PM
j8's Avatar
j8
Look here
https://www.evolutionm.net/forums/sh...ght+adjustment
Old Jun 18, 2005 | 03:38 PM
JSYEVO's Avatar
just one question, does electronic tilt still work after you do that? so like if i had it at "0" and adjusted it, would it go higher if i moved it to "4" or would the electronic tilt not work anymore?
Old Jun 18, 2005 | 03:57 PM
nubby's Avatar
Registered User
Headlight adjustment will still work from the cabin. Here's a picture that may help:
Old Jun 18, 2005 | 04:22 PM
JSYEVO's Avatar
ok, i think i see the drivers side one, its like a double sided gear, and the 10mm socket is suppose to go like on the center and turn. but the passenger side i see where they want me to put the driver but its blocked by like a metal thing. and do i HAVE to use a 10mm socket? or do both of them adjust with just a driver?
Old Jun 18, 2005 | 06:04 PM
onesicklambo's Avatar
i have the same problem...i think its because my car is lowered? Is yor car lowered? I have the in cabin knob adjusted all the way up and its still to low
Old Jun 18, 2005 | 06:14 PM
nubby's Avatar
Registered User
I just checked the service manual, and it's of very little help as far as adjusting the headlights. I checked to see if there were any specific instructions for the right-hand side, but that picture I posted up is just about all they have telling you where to perform the adjustment.
Old Jun 18, 2005 | 07:24 PM
temps's Avatar
rofl. sad to say this but i had no idea we could adjust the HIDs...
Old Jun 18, 2005 | 07:33 PM
BoostWhore's Avatar
10mm socket stick it on the gear on the outtersides of the headlights works perfect, and the electronic adjustment still works
Old Jun 18, 2005 | 07:39 PM
SilverStreak's Avatar
I made this adjustment on mine. It was extremely simple and it made a huge difference. My car is lowered 2" in the front, so you can imagine how much pavement I was looking at. I made my adjustments using the 10mm socket wrench. It took quite some tweaking to assure they are even with eachother, especially if you're a perfectionist like me. I lined the car up to a wall, and made my adjustments matching the beams on the wall. Let me know if you have any questions. I think it took a whopping 15 minutes to complete.
Old Jun 18, 2005 | 07:41 PM
*Make sure you have the headlights off when making the adjustments. It's said to make your headlight motors freak if the lights are on.
Old Jun 18, 2005 | 08:02 PM
blueo4's Avatar
lets face it evo lights suck!
easy way around this is to black out your headlights, take out the fog beam diffuser and increase the rating of the hid bulbs & fog light bulbs.
get all done at once so you can be done with it and not have to remove the bumper again!
atleast that whats i am going to do
Old Jun 18, 2005 | 08:27 PM
^Actually...once you've made this adjustment, your high beams will be obsolete. I can't even notice a difference when I have my HB's on. The only upgrade I made was to the fog light bulb, which still points low, as it should. This is such a simple adjustment and it really makes a difference.
onesicklambo...I returned your PM.
AutoMotoSports
Automotosports - Illinois
30
Aug 5, 2018 10:55 AM
ExViTermini
Jul 20, 2008 08:31 PM
wtz
Jun 25, 2007 09:39 AM
chuntington101
13
May 11, 2007 12:04 AM
sdhotwn
Lancer Engine Tech
49
Jan 1, 2004 07:20 PM
