Emissions?
Old Jul 1, 2005 | 05:44 PM
skrib's Avatar
Emissions?
I know it goes by different states I believe but, those who do aftermarket parts on their cars here in new york, how do u pass emissions every year. Does it come down to pretty much just knowing someone or finding the right people? The thing is now I didn't buy this car myself, yea my parents did. I want to do some after market parts like an exhaust system and so on but they said i can do what i want as long as it passes emissions. So if theres any tricks people may know about im curiuos to know thanks.
Old Jul 1, 2005 | 05:49 PM
Scuba2001's Avatar
Im not sure about NY, but I know with most states it has to pass a visual check and an emissions check where they put you on a dyno or something of the sort and check everything while the car is running. So, you may be able to pass the emissions part, but the visual check is going to be key.
Old Jul 1, 2005 | 05:54 PM
jjm4life's Avatar
i know im from boston but i got a lot of friends in ny. one of them had a highly modified jetta 1.8t and he had no trouble passing emissions and it was easy to tell it wasnt stock. hope this helps.
Old Jul 1, 2005 | 05:58 PM
Aikido's Avatar
The 10 sec evo kit that costs 16,000 dollars, i can't think of the company that does it. There located in IL. Anyways i asked the guy in charge about it. I Live in PA so i told him about the emissions. He reassured me 100% that i would pass emissions. So if that passes emissions then you should be fine. Only thing that i think would make u fail automatically is a Test pipe, so just get a high flow cat on your TBE.
Old Jul 1, 2005 | 06:46 PM
ddubb's Avatar
I'm not 100% sure but in IL they change the format and don't hook up anything to the exhaust anymore, last time I brought in my tahoe they just plugged into the ecu and ran a test and passed. I assume it's going to be the same deal with my evo when the time comes. I hope I pass
Old Jul 2, 2005 | 09:52 PM
skrib's Avatar
hmm im pretty sure here in ny they check out the exhaust
Old Jul 11, 2005 | 05:22 PM
kyJelly's Avatar
if you have a cat and the stock ecu you should be fine
some states plug into your obd port and look for a cat
Old Jul 11, 2005 | 05:24 PM
UT_Evo's Avatar
As long as the exhaust passes the "sniff test" thing and has a visable catylitic (spelling?) converter then it will pass the full emissions test.
Old Jul 11, 2005 | 05:27 PM
topnotchevo's Avatar
N.Az. no emissions, no cats ..WIDE OPEN EXAUST..4"!!!
andyliciousMRIX
Northwest Region
16
Mar 23, 2011 02:31 PM
sdfontanini
E85 / Ethanol
Apr 1, 2009 09:07 PM
jamsky
May 9, 2008 11:06 PM
LT1runner
Automotosports - Illinois
16
Apr 15, 2008 06:03 AM
batmoEVO
Midwest Region
20
Aug 20, 2006 03:56 PM
