Wrapping the exhaust
What i know is that the bigger the exhaust, the more power you get for decreasing backpreasure . But the problem is as you increase the diameter of your exhaust the sound becomes really loud and annoying.
So, i just had this idea and would like to discuss it. What if i used sound deadening barriers like the one offered by ThermoTech and wrap it aroung a 5" exhaust . It protect against excessive heat and noise. The only problem that i can think of is that the exhaust gases will be really hot .
So, what is the problem with high EGT?
And does this idea sound reasonable?
some backpressure is actually a good thing. Without it, you'll get boost creep. Also, how the hell are you going to clear the damn sub frame connectors?
And I swear if I ever see an Evo driving on the street with a 5 inch exhaust, I'll shoot the driver.
Wrapping is good. Only egt near the manifold is important to engine conditions. High egt in the exhaust part means the exhaust is retaining the heat allowing it to escape faster. Seriously some 1000hp+ supras are running 4 inch exhausts.
tavo_evo
59
Apr 21, 2016 05:37 PM
