Boost leak? How tight do clamps need to be?
Old Jul 26, 2005 | 08:53 AM
jdoc7's Avatar
When installing a BOV, how tight should the clamps be? I'm thinking I may have a boost leak and the BOV was the only thing I touched. Wasn't sure if the clamps need to be as tight as they will physically go or what. Appreciate any advice.
Old Jul 26, 2005 | 08:55 AM
Curt@MrLed's Avatar
Former Vendor
till there tight, or the leak stops.. what are you trying to find from us torque specs..
Old Jul 26, 2005 | 09:05 AM
Kronik's Avatar
well a rule i go by is to watch the clamp as you are tightening it ...you should begin to see the top part the clamp begin to overlap the bottom and then eventually cross one side of the lower portion of the clamp (geez, that didn't make a whole lot of sense...)....once you are there you should be golden.
It's easier to describe when you see it -- i hope that makes sense. And oh yeah, use a socket instead of a phillips too..
Old Jul 26, 2005 | 09:07 AM
jdoc7's Avatar
No, don't need torque specs. There just seems to be a lot room for tightening since it is a rubber hose which compresses and, the clamps are ratchet type that can and will tighten down to the point of crushing the hose if too tight. Just wasn't too sure what 'until tight' means.
Old Jul 26, 2005 | 09:15 AM
BJai02's Avatar
It is more important to align the the BOV to teh insert than over tightening it. Make sure it goes in straight, not at any angle.
nonschlont
Jan 20, 2011 04:59 PM
BluEVOIX
10
Dec 26, 2008 07:05 AM
scottatyamaha
15
Oct 15, 2008 02:51 PM
TogueMonster
19
Oct 27, 2006 01:07 AM
ruthless evo 8
12
Oct 18, 2004 09:32 AM
