I hate my brakes
Old Jul 29, 2005 | 10:01 AM
  #46
OldschoolEVO's Avatar
when I changed the pads on my VI I didnt use shims but I did use copper anti-seize and some anti squeal compound along the edges of the pads. So far almost a year later Ive had no squeal at all.
Old Jul 29, 2005 | 02:48 PM
  #47
MaxR's Avatar
"you may have to endure brake squealing. You can never completely avoid these side effects when you tune your car to its ultimate performance level."
quote
Mr. I. Kimata
Ralliart Japan High Performance Catalog
Old Jul 29, 2005 | 03:53 PM
  #48
Zeus's Avatar
Many people's problem is that they only used 1/2 the OE shims. Yes, you reused the OE metal shims, but you failed to peel off the fiber shims from the backs of the OE brake pads. They are glued on. You can run some pretty aggressive pads on the Evo with minimum squeal if you reused both the metal shims, and the fiber ones with your anti-squeal compound... along with proper bedding.
Old Jul 29, 2005 | 04:35 PM
  #49
Jonasan50's Avatar
I got my calipers changed under warranty for the peeling paint.. When I did that, I purchased Brembo drilled rotors and put factory pads back on them.. No squeels, brakes really good, no complaints here.. My .02
Old Jul 29, 2005 | 05:44 PM
  #50
straightrider's Avatar
i never had tried it but my friend did
he says if u go about 30mph and slamm on your brakes it will get rid of the sound but will probly return in like a week or something like that
Old Jul 29, 2005 | 07:20 PM
  #51
trinydex's Avatar
all hawk pads will squeel except for their non squeeling pad. all carbometallic pads squeel. my titan kais do... that's just the commitment you make when you get race pads. you can try the cerametallic pads... maybe some pfs or ferrodos.
Struc
27
May 8, 2015 09:39 AM
03evil8
Oct 14, 2013 12:48 PM
Montu
165
Jul 26, 2013 11:23 AM
pcguru2000
Lancer Troubleshooting
May 10, 2013 06:43 AM
catman78
22
Nov 14, 2011 08:00 AM
