Guess MY DYNO NUMBERS....
Old Aug 3, 2005 | 06:41 PM
Dyno4mance's Avatar
What Dyno was it?....I assume because the #'s are so high it was a dynojet..It doesn't even look like you have anything other than a boost controller....do you have any A/F or timing modifications?
105 degrees and 7% humidity in Jersey???...that does not sound right, that is more like dessert conditions!!
Old Aug 3, 2005 | 06:55 PM
navysevo's Avatar
you should read the first part of my post it lists all my mods and i think jersey is hot as **** i guess you never been here and in a shop with no a/c and nothing but heat build up maybe your wrong basically i was just asking if the torque could be brought up and how but i guess i will call turbo trix in the morning to find out.
it is a dynojet at turbotixracing in edison new jersey today
2005 mr was also dynoed today with same mods at 23psi i am waiting to find out what he did...i was first on the dyno and didnt stick around to see what he got but i will find out.
Old Aug 3, 2005 | 06:56 PM
navysevo's Avatar
i gues i just have to post the dyno chart brb.
Old Aug 3, 2005 | 06:59 PM
plokivos's Avatar
320 319
edit: oops. post result guess.
Old Aug 3, 2005 | 11:10 PM
Warrtalon's Avatar
Well, he was referring to the 7% humidity...it was more like 70%.
The 50 less awtq is weird. I'm guessing the dynochart will show us an abnormal HP spike...
Old Aug 3, 2005 | 11:12 PM
plokivos's Avatar
what was your baseline dyno and one before this one?
Old Aug 4, 2005 | 04:35 AM
Dyno4mance's Avatar
Yes I was...You will never see 7% humidity on the east coast IMO
Old Aug 4, 2005 | 05:32 AM
navysevo's Avatar
dyno charts
here they are one is with and without the fuel pump the other is the last run they made and no i didnt get a baseline reading
i wish i asked now for it
https://www.evolutionm.net/forums/sh...d.php?t=151998
thats the other thread with the dyno results
Old Aug 4, 2005 | 06:24 AM
Dyno4mance's Avatar
HHHMMMM....you changed the fuel pump and made more power?
Was there a problem with fuel delivery then?
was there a lean condition before the fuel pump was switched?
JaReDbOy
Apr 2, 2009 07:43 PM
RUN FOREST RUN
Feb 9, 2008 08:18 AM
David Buschur
18
Sep 20, 2005 02:10 AM
jspecEVO
Midwest Region
Oct 23, 2003 01:59 PM
