Anybody else seen this???
Old Aug 5, 2005 | 11:40 AM
tbizzy85's Avatar
I just installed Downpipe and test pipe.
I noticed a sqeek coming from underneath me over bumps and under accel, it's not too bad though. So I took it to school to put it on a rack and I noticed the exhaust hangers on the DP aren't holding any of the exhaust weight. So the mounts on the DP are rubbing against the two black hangers and squeeking.
Also I have the HKS hi power cat-back. I noticed the resonator has been worn down a bit. With further inspection I realized that the drive shaft (under heavy tourqe) is twisting over and rubbing against the exhaust. The Carrier bearings for the drive shaft have some play. I can take them and move them I'ld say just under 1/2 an inch.
Has any one had this happen??? Also if you can get under your car and move the drive shaft see if you think 1/2 an inch is excessive.
Thanks for any replies.
Old Aug 5, 2005 | 11:44 AM
evo_il8's Avatar
there was a thread about this recently that had the same exact thing happening
Old Aug 5, 2005 | 11:45 AM
evo_il8's Avatar
ill try to find it if i can
tbizzy85's Avatar
Oh thanks
Old Aug 5, 2005 | 12:50 PM
Emo-Evo's Avatar
I have an hk$ and it has the rub spot on the resonator too
Old Aug 5, 2005 | 01:05 PM
tbizzy85's Avatar
I used a paint stick on the rub spot to see if it's still rubbing, I'll check it at school again on monday. I just don't want it to rub through the resonator
Old Aug 5, 2005 | 02:02 PM
EvOJoHnY0312's Avatar
did you instll it right.. rookies i tell ya
Old Aug 5, 2005 | 02:46 PM
Jonasan50's Avatar
I have the HKS cat-back as well and it has PLENTY of clearance.. Make sure it's installed correctly...
Old Aug 5, 2005 | 02:57 PM
tbizzy85's Avatar
It's installed correctly, I'm an ASE certified tech and I un-bolted it and reinstalled to make sure. By no means am I a rookie when it comes to installing. But honestly, thanks for the ideas guys.
I think it has something to do with the Carriers having so much play....O'well I'll mess with it at school monday and tell you guys if I can figure anything out.
Thanks
Fizylftingdrnks
Jul 29, 2016 11:31 AM
Joemflsxe
ExtremeTurboSystems.com – WA
Sep 9, 2008 10:49 PM
reggiesd
Dec 11, 2006 11:40 PM
smp3000
Aug 11, 2005 07:51 AM
Shingen
Feb 15, 2005 10:38 PM
