Audible flutter during acceleration
Old Aug 16, 2005 | 05:20 PM
TheDriver11421's Avatar
okay, my car is actin up now. Occasionally, when i accelerate, my car spools to 15psi quickly and then struggles to get to max boost (22psi). There is a very audible fluttering heard when it does this. It doesn't happen all the time, but it happens more than half of the time. I don't think it's a leak in the piping, because when it does actually hit max boost, it holds. Also, t-bolted all the IC pipes, so i dont think it would be that. I do have a new BOV, but i've tweaked it enough to know that it's not that, i also put the stock bov back on, and got the same issue. Does anybody have any ideas? It's not my boost controller, because i tried with the stock boost solenoid and still got the same problem. Could it be a hose, or line somewhere? Possibly my actuator got messed up. any help is appreciated. thanks guys
Old Aug 16, 2005 | 05:32 PM
werra's Avatar
sorta sounds like a vacuum line somewhere has popped off.
Thegame's Avatar
I would suggest BOV, but since you tried with the stock one too with no success I'm really not sure. I don't mean to insult you, but are you sure that you are installing the BOV's correctly? That's the only thing I can think of that will cause your kind of problem. A leak is definately not going to let you hold 22psi.
Old Aug 16, 2005 | 05:43 PM
no insult taken. Yeah, i installed it correctly. I dont think its a leak, because it occasionally does hit 22psi and holds. I'm thinking its the actuator. I just wanna hear if anyone else ever ran into this issue.
Old Aug 16, 2005 | 05:44 PM
checked em, replaced em- all seemed okay.
Seth_Horton92
Feb 9, 2017 07:13 AM
jd888jd
17
May 8, 2009 06:47 AM
neodestroyer
59
Apr 9, 2009 09:42 PM
bboy_RES
Feb 27, 2008 01:30 PM
bishiboy
60
Jun 25, 2004 10:53 AM
