turbo lag between shifts?
Old Aug 27, 2005 | 07:53 AM
hueman's Avatar
won't powershifting screw your tranny up pretty quickly?
Old Aug 27, 2005 | 08:03 AM
marks03evo's Avatar
not if you only do it when you race once and awhile...
Old Aug 27, 2005 | 08:15 AM
VIIImylunch's Avatar
Mine spools really fast. 2 secs is a little slow.
Old Aug 27, 2005 | 11:50 AM
AzBlackEvo8's Avatar
Since you're racing, shift at Higher RPM like maybe... 7K or even couple hundred more so when you're in the next gear (shifting fast of course), you should be still in full boost.
Old Aug 27, 2005 | 12:01 PM
bbyevo8u's Avatar
your shifting to fast let the rpm's drop a little more so your back in the power band
your speed wont change and you will have more gear
try it let me know what you think
Old Aug 28, 2005 | 09:46 AM
Aikido's Avatar
i love when peoeple just make up assumptions, of course it's going to mess up your tranny, stock clutch and tranny won't be able to handle that kind of shock very long. For fu.cks sake if you don't know don't just make **** up.
Old Aug 28, 2005 | 10:56 AM
marks03evo's Avatar
yes its not that good for the car but its not going to **** up the clutch or tranny if you only do it when you take it down to the track once every month or so...chill out
Old Aug 28, 2005 | 11:09 AM
4TUN8's Avatar
Don't powershift man, you're not a racecar driver, and it's only going to screw up your tranny.
Old Aug 28, 2005 | 11:19 AM
Warrtalon's Avatar
What in the HELL are you talking about? Shift slower to let the rpms drop more so that you're back in the power band???? You cannot be serious. This is the exact opposite of what you're supposed to do when racing. Shift as FAST as possible and try to keep the RPMs as HIGH as possible when engaging the next gear. We make peak HP at 6800. There's no reason to want to be LOWER in the powerband...
Old Aug 28, 2005 | 11:21 AM
Warrtalon's Avatar
Originally Posted by JSYEVO
do you guys get a lot of lag between shifts? like when im racing it actually has to spool back up and it takes like 2 seconds to get back to full boost, is that normal?
When racing, shift as fast as possible and don't shift until after 7k rpms...preferably around 7100-7200. There should be no re-spool time required after a quick shift unless your car is messed up or you just shift poorly.
Paul Nelson
AEM EMS
13
May 31, 2008 09:35 PM
gaijin
Dec 31, 2005 08:33 PM
negativeB
Sep 17, 2004 01:23 AM
DefBringer
17
Jul 15, 2004 10:00 AM
dima126
May 8, 2004 07:06 AM
