Notchy Shifter
Old Aug 26, 2005 | 11:10 AM
dridge11's Avatar
Notchy Shifter
Does the shifter get a little more fluid and smooth as the car is broken in? It just seems kinda clunky right now. Maybe it's just because it's a shorter throw than I was used to before.
Old Aug 26, 2005 | 11:16 AM
shivaswrath's Avatar
it gets a little better I guess. . I'm at 1500 miles now. . . .I like to row through the gears for a bit on start up, get the gear fluid all over the synchros, etc. . .that usually helps get rid of SOME of the notchiness. . . .it's not Honda-snick-snick, but it's pretty good. . . .
Old Aug 26, 2005 | 11:22 AM
Compjoc's Avatar
Get some GM synchroshift or some penzoil synchromesh (very similar products). That will help out alot.
dridge11's Avatar
Good suggestion, I'll do that as well. I know it's not the cold temperatures!
Old Aug 26, 2005 | 12:11 PM
yeah I know man, I was in Dallas last weekend, freakin' cookin' up there, just as hot as it is here in Houston. . .
I don't know if the dealership will void any sort of TSB thing on the synchro's if you change out the gear fluid though. . .experts chime in?? I'd get the 4-5 TSB done before you make a switch. . .
Old Aug 26, 2005 | 12:13 PM
Kronik's Avatar
Heck, get shifter bushings! That will make a HUGE difference!!
Old Aug 26, 2005 | 03:45 PM
LoyalTrojan's Avatar
Your shifter will get a lot smoother as you drive around more. I got 18K miles on my 03, and I still hear clunking noise when I shift from 1st to 2nd and sometimes from 2nd to 3rd, but it goes away after I drove for a few minutes...
Old Aug 26, 2005 | 04:44 PM
jjm4life's Avatar
i have abotu 3k miles on mine right now and i always let it warm up a bit before i start driving. its been really hot here in philly this summer and still the first couple of mins of driving it is very notchy, but it starts to get smoother with time. like it was said before its no honda, but it does the job
Old Sep 11, 2005 | 12:45 PM
dridge11's Avatar
If I replaced it with the syncomesh or syncoshift, are these the instructions to change it?
http://www.evomoto.com/tech_info.php?tech_id=26
Old Sep 11, 2005 | 01:01 PM
Tom Sawyer's Avatar
Mine has gotten less notchy as it's been broken in, 1600 miles now. Still not butter smooth shifts like my GSX but that's the sacrifice we make for the durability.
Tom
Old Sep 11, 2005 | 02:37 PM
Silk's Avatar
Mines notchy but once its warmed up it gets smoother. I just try not to shift to quick when just after just starting the car.
Old Sep 13, 2005 | 09:33 AM
dridge11's Avatar
Repeat...are these the right instructions?
Old Sep 13, 2005 | 09:57 AM
nj1266's Avatar
Yes, they are.
Old Sep 13, 2005 | 10:19 AM
TxEvo8's Avatar
The shifting action will never be "Honda smooth", but you will get used to it. It is normal.
Old Sep 13, 2005 | 10:21 AM
dridge11's Avatar
Thanks!
I'm not shooting for Honda smooth, just want to minimize the clunky feeling as much as possible.
