20G Fever!
Old Sep 25, 2005 | 05:13 PM
EVO_8's Avatar
Originally Posted by 1.8t
Al, when did your dual stage map become available? And how much would it be for a custom tuned customer to upgrade to it?
I'm also interested in this kind of setup.
How much would it cost to flash a stock (never flashed) ECU ?
Also, how do you switch between the maps ?
Old Sep 25, 2005 | 05:14 PM
hashi's Avatar
i want
Old Sep 25, 2005 | 05:25 PM
4G63 T's Avatar
+1
Originally Posted by 4TUN8
Al,
How are maps switched on the v2 flash?
Old Sep 25, 2005 | 05:26 PM
DragNRacing's Avatar
+2
Old Sep 25, 2005 | 05:35 PM
BoostWhore's Avatar
If im not mistaken i think when u go over like 23psi or so the stock ecu has a second map that takes over. I may be wrong. Im really interested in one of these is injectors needed on an 03 w/ a walbrol? how bad is the compressor surge does the car jerk?
Old Sep 25, 2005 | 07:04 PM
05-EVO-GSR's Avatar
What is compressor surge?
Old Sep 25, 2005 | 09:37 PM
DynoFlash's Avatar
Al,
They switch automatically when you increase your boost level
Its the "dual stage " flash that does that aspect
The V2 refers to the data logging system I have incorporated to inhance the accurancy of the tuning and also to provide all Dyno Flash customers with the info on how the car is tuned and how it is running
Old Sep 25, 2005 | 10:07 PM
Ozzmosis's Avatar
Waite you have a flash that holds Two maps and shifts between them on the Fly? That's amazing.
Old Sep 25, 2005 | 10:56 PM
2jzEVO's Avatar
i'll interesting to go with that setup
Old Sep 25, 2005 | 11:01 PM
Erik@MIL.SPEC's Avatar
Typically when the compressor wheel is to big compared to the turbine wheel. David even mentioned that there was partial-throttle surge when some guy was driving one of their cars around. Apparently (from what Al wrote) it is only noticable on spool-up, so I'll leave this to people who know better than I do regarding this turbo. I think the clipped turbine wheel was supposed to alleviate this somewhat.
Old Sep 26, 2005 | 08:07 AM
DynoFlash's Avatar
On the compressor surge - Just about every 20 G modififed subaru turbo I have driven does the same exact thing - its very common on those type of turbos. Not a big deal just something to be aware of if you are considering one of these units.
Old Sep 26, 2005 | 08:09 AM
NocturnalEVO's Avatar
What kind of issues can you have with compressor surge?
Old Sep 26, 2005 | 08:27 AM
sleet's Avatar
It'll be interesting the numbers it throws down
Old Sep 26, 2005 | 08:43 AM
construct1's Avatar
compressor surge, hmm premature wear on bearings and fatal brake down possible, some one correct me if wrong here.
called BR on friday and do not have the parts in stock right now
Al how bad is lag on this turbo comapared to stock?
Old Sep 26, 2005 | 09:01 AM
Creamo3's Avatar
The car Al is referring to is me. Take a look at my mods list for a full run down. It is definately running strong
