20G Fever!
Old Sep 27, 2005 | 04:41 PM
  #76
jj_008's Avatar
Originally Posted by propellerhead
I can personally attest that a GT35R w/ a .63 A/R turbine housing on a 2.3 stroker will surge like an SOB under part throttle conditions. It leastmy set up is. It's pretty much undrivable on a road course. It can probably be tuned around by creating a boost profile to avoid the surge areas of the compressor map. Perhaps a larger turbine housing would help too. Unfortunately I don't have the time resources to do the R & D. I'll wait it out until I can find someone that has hands on experience with building a combination that works well for road course usage.
Are you using a surge ported compressor cover? If not, then you should invest in one.
Old Sep 27, 2005 | 07:13 PM
  #77
Widebandphillip's Avatar
Originally Posted by DynoFlash
I am going to try and go at it by drilling some holes in the compressor cover
Maybe David has tried that already
Did anyone else find this funny?
Old Sep 27, 2005 | 07:35 PM
  #78
MalibuJack's Avatar
Originally Posted by trinydex
happens in the canyons for me... which is pretty annoying cuz then you gotta break the pace.
anyway... why did you let the good ol 1g go mj?
Testing different BOV's, Testing a Forge 1G valve now.. at least when the car comes back from the body shop... I have the old ones in boxes, but I had two or three 1G DSM valves, and the one with the leak stop kit seemed to disappear recently, probably tossed in a box and forgot where I put it.
Old Sep 27, 2005 | 07:39 PM
  #79
MalibuJack's Avatar
The image that popped into my head was a cover with lots of holes drilled in it.. but I think I understood what he meant..
Old Sep 27, 2005 | 07:45 PM
  #80
propellerhead's Avatar
Yes, I have a ported compressor cover. Surge is not a problem while under WOT conditions, only during part throttle under boost.
Old Sep 27, 2005 | 07:46 PM
  #81
DynoFlash's Avatar
Actually most of the GT35R turbos being sold now have exactly that - holes drilled in the cover of the compressor
Here is the turbo I am thinking of trying out with my new stroker engine - notice the holes they drilled
http://www.hksusa.com/images/?id=2128
Old Sep 27, 2005 | 07:52 PM
  #82
MalibuJack's Avatar
Yah, thats what I understood it as.. But the image was a compressor cover that looked like swiss cheese.. all over.. I have a spare compressor cover, I should take a look at it and see how much meat there is for something like that.
Old Sep 27, 2005 | 07:55 PM
  #83
DynoFlash's Avatar
Although I am no engineer - from what i have read certain compressors can actually pick up in certain areas of the compressor map with some holes drilled in the cover or a surge port
Old Sep 27, 2005 | 08:02 PM
  #84
trinydex's Avatar
that is called surge porting. you might not wanna take a hand drill to it tho... something more precise is better. fp does it for a price... you can also get a surge ported ring.
Old Sep 27, 2005 | 08:14 PM
  #85
kiddevo's Avatar
what bov will help reduce surge on 20g?Should u get a high boost wastegate actuator with 20g and using race gas or alky
Old Sep 27, 2005 | 08:22 PM
  #86
Drifto's Avatar
I have not found good results on the 3076
https://www.evolutionm.net/forums/sh...highlight=3076
Sounded like you liked this one.
Old Sep 27, 2005 | 08:33 PM
  #87
Mr. Slappy's Avatar
Sorry Al but I think your opinoun is skewed seeing how you want to sell Buschur's parts.
Old Sep 27, 2005 | 10:08 PM
  #88
DynoFlash's Avatar
Originally Posted by Drifto
Yes I did like that one - but in that thread I was simply saying that the particular kit I was tuning turned out fairly well
No one was asking for my opinion on which turbo to buy
Old Sep 27, 2005 | 10:12 PM
  #89
DynoFlash's Avatar
Buschur may be my friend and I want him to do well - BUT - facts be known I DOP NOT make any money recomending Buschur 20G's. I have no 20G's to sell and I dont get any referal fees.
I could just as easily be saying that the XZY brand turbo is the best - it does not matter I dont sell either
I am simply a tuner - period
I want my customers to get the best parts possible and the 20G is something I think they will enjoy
If the turbo turns out to be weak and suck - then my credability is shot
I don't think I would suggest it unless it was performing really well in my tuning
Take my suggestions for what they are - simply a suggestion
Old Sep 27, 2005 | 10:39 PM
  #90
YankInCali's Avatar
Al thanks for the review and the great feedback to the responses!
Since we're all talkin' 20G, I thought I might bring this turbo up.
http://www.lancershop.com/customer/p...?productid=739
A 20G titanium aluminide wheel in a TME 6.5 sounds like a good choice to bring spool back to stock levels...
