the 1st thing i should do.
Old Oct 13, 2005 | 05:10 PM
  #46
Warrtalon's Avatar
Originally Posted by FL_SilverEvo8
thanks everyone again for posting on my thread. i already have a boost gauge. still tyrin to read about exhust. don't know what one to use. i like the AMS TBE, but it kind of costly. the buscher TBE seemd like it was built with left over parts they had at their shop. don't get me wrong on this but the do have good gains from what i have seen on their web site.then thier is the invidia tbe i hear that exhust has a life time warranty. and when i do my intake i will do a flash first.
Megan TBE or LPI TBE (3" turboback) = $550-600 and looks nice
Don't get an intake...
Old Oct 13, 2005 | 05:31 PM
  #47
silvery_eagle's Avatar
Don't get an INTAKE! x 10000
this has been covered like million times
Old Oct 13, 2005 | 05:42 PM
  #48
FL_SilverEvo8's Avatar
what do you all think of buscher stage 1 kit vs. ams stage 1 kit? are the stages the way to go for upgrades?
Old Oct 13, 2005 | 06:13 PM
  #49
romogst's Avatar
Intake+Full Exhaust!!!
Old Oct 13, 2005 | 08:01 PM
  #50
get faster's Avatar
The real best advice is to Do nothing but drive your car. learn about it, enjoy driving it. Spend on gas and anything else that needs replacing. Then drive some more. Love your car stock.
Then if you still want to add mods. Before you buy anything go to the track and time your car (and yourself). You may also want to dyno your evo but that wont tell you how fast YOu and your car will be when you dance together.
First mod should be to improve your stopping range and second should be in protecting your turbo.
Always document your mods. Don't waste $$$ on BOV untill you have changed a few other parts. Forget the intakes unless you have a good tuner. Search this site. read. but dont forget to just be happy driving your car.
Warning: When you start to modify, expect some problems that may have you wondering where your loved car is gone.
Old Oct 13, 2005 | 09:20 PM
  #51
evotino's Avatar
Get exhaust first. The sound is cool, it adds horsepower immediately, saves weight, and is necessary in the future when you want to make bigger numbers. Go for 3" piping.
Old Oct 14, 2005 | 12:19 AM
  #52
Evoegg's Avatar
Originally Posted by AWDTurbo4
tinted windows
+1 das what I did ...
Old Oct 14, 2005 | 12:28 AM
  #53
2hot2handle's Avatar
DONT get and INTAKE...DROP in filter at most!
Old Oct 14, 2005 | 09:33 AM
  #54
is buscchers stage 1 kit a good way to go? i am think about doing that. so far i have been hearing good news about buschers stuff.
Old Oct 28, 2005 | 04:20 PM
  #55
justin21's Avatar
well frankie im new to posting on here but for the first few mods i plan on k&n drop in cuz its cheap and will help a lil. aps 3.5 turboback i know a lil overkill for stock turbo but plan to upgrade to probaly garret gt later. thats about it well a good tune i like aems ems had it on my 91gsx.
Old Oct 29, 2005 | 08:52 AM
  #56
ballistic speed's Avatar
Catch cans for dragers are different from our catch cans. Drag cars have oil release valves that vent sludged up oil from the engine. Our cars have a similar system called PCV (Positive crankcase ventaliation), any acidic and gassious oil that can casue gunkup will be vented through a PCV valve into the intake manifold where it is reburnt there. Since this acidic or gassous oil is produced my moderate blow by past our piston rings, our turbo cars will have more of the acidic or gassous oil since we are boosting. Now the problem lies where we vent that stuff back to the intake, first off, it degrades the combustion mixture + has some moderate degree of puting sludge into the manifold and the engine. Oil burnt in the engine has tons of extra carbons thus build up carbon as well. Catch can is a good investment to the purity of our intake air and keeping the engine clean.
Old Oct 29, 2005 | 12:45 PM
  #57
muzak's Avatar
Originally Posted by AWDrift07
To each his own. i don't like sitting in my caridle for 5+ minutes or going inside and then running back outside to turn it off in a few minutes.
From what I have read here, the turbos on the Evo don't need that much time to cooldown. I thought they did at first, because I am thinking about an RX-7. I think they only need about 30sec-1 min to cool, as long as you don't boost into ur parking space.
Old Oct 29, 2005 | 01:04 PM
  #58
kutschca's Avatar
ding ding ding..for a very good answer. As most previous DSMers will tell you, there is noticable blow-by on the 4g63 motors, especially when modded. Over time you'll coat the inside of your intake with a nice oily residue, which reduces the efficency of the whole system
Old Oct 29, 2005 | 05:32 PM
  #59
IXMR's Avatar
if you did decide to get an intake (don't) why would you get a flash BEFORE you did the intake it should be vice versa , the intake then drive the sputtury spitting car to the tuner and ask him to try to get it running good
hope this helps in the future
Old Oct 29, 2005 | 05:53 PM
  #60
dubbleugly01's Avatar
To each his own. i don't like sitting in my caridle for 5+ minutes or going inside and then running back outside to turn it off in a few minutes. It does save the turbo, i've seen tons of gummed up turbos from not being cooled. I like being able to turn on my timer and forget about it and not worrying that someone could steal my car. Its more or less a piece of mind or even a luxury item imo.
i agree that a boost gauge is a great first mod. it impresses the ladies also. also if you are using boost control, a A/F meter and/ or gauge is a good idea. A/F ratios give you good insight on whats going on in your engine and how boost is affecting it.
you've seen tons of gummed up turbos that have water cooling in addition to oil on the center cartridge, that run mobil 1 and change it every 5,000 miles max???? That's a new one on me.
