the 1st thing i should do.
Originally Posted by dubbleugly01
you've seen tons of gummed up turbos that have water cooling in addition to oil on the center cartridge, that run mobil 1 and change it every 5,000 miles max???? That's a new one on me.
BTW just to save you a post, yes, mitsubishi makes the turbo for the WRX.
Originally Posted by get faster
The real best advice is to Do nothing but drive your car. learn about it, enjoy driving it. Spend on gas and anything else that needs replacing. Then drive some more. Love your car stock.
Then if you still want to add mods. Before you buy anything go to the track and time your car (and yourself). You may also want to dyno your evo but that wont tell you how fast YOu and your car will be when you dance together.
First mod should be to improve your stopping range and second should be in protecting your turbo.
Always document your mods. Don't waste $$$ on BOV untill you have changed a few other parts. Forget the intakes unless you have a good tuner. Search this site. read. but dont forget to just be happy driving your car.
Warning: When you start to modify, expect some problems that may have you wondering where your loved car is gone.
First of all... ITS YOUR CAR, do what you want to it. dont let people tell you what to get on your own car.
These are my sugestions : exhaust (whatever brand you want), Intake, JDM MR DV or forge rs BOV, hallman or forge UNOS MBC, LICP, And a tune of your choice (mail in is the most convenient).... or just look at Warrtalons sig and click on the link.
Enjoy your new EVO
Enjoy your new EVO
Originally Posted by donmeca2020
definetly get a turbo timer, it extends the life of the motor.
Originally Posted by FL_SilverEvo8
the first thing i was gone to do was the intake,BOV,and a manul boost controler. then my turbo back exhust. how is this for parts:
intake- InJen w/ hard pipe
BOV-HKS super sequential (with that kind of bov i know i need a hks eid. b/c of the maf senor)
for tubo back exhust i was thinking Invidia. how do you all like my lil list? is that a good start off point?
thanks
frankie
thanks
frankie
Good luck I can tell you most of us have been gun happy with mods and learned the hard way what works and what doesn't. Best of luck
Come on, man, not it doesn't. A turbo timer has nothing to do with the motor. It also doesn't help the turbo unless you go WOT into your parking spot everyday.
Originally Posted by MYEVOVIII
Normally I agree with your comments but your wrong on this one. A turbo timer allows the water and oil to circulate in the turbo to cool off the bearings and oil, this in turn will keep any oil from baking on your bearings and causing build up which over the long haul can lead to bearing failure and result in either a rebuild or buying a new turbo.
MDonovan
13
Jul 26, 2002 10:19 PM
