free mods
Old Oct 12, 2005 | 01:58 AM
t88h supra's Avatar
free mods
There always seems to be free mods for a car (like pulling a certain fuse, changing some wiring.....). I've searched for the evos but haven't come across any. Do you guys know any?
Old Oct 12, 2005 | 02:00 AM
2hot2handle's Avatar
UNIVERSAL.......unbolt the exhaust from the cat (if you can live w/ the fumes ) j/p
Old Oct 12, 2005 | 02:16 AM
8ASTI's Avatar
thi k the fumes may have started to take effect on ya...
Old Oct 12, 2005 | 06:44 AM
sirloin1219's Avatar
Im Addicted To Teh Fumes!
Old Oct 12, 2005 | 06:48 AM
GOKOU's Avatar
1. remove/rewire the coolant line to the TB.
2. Adjust the throttle cable for better response.
Old Oct 12, 2005 | 06:49 AM
nyrican's Avatar
T88H ....hmmm...sounds familiar, is this Brian?
Old Oct 12, 2005 | 06:50 AM
J8dailo's Avatar
you can rewire the taillight for a special effect
Old Oct 12, 2005 | 06:51 AM
shimla's Avatar
looks dept.: cut the upper thinner part of the antenna from the thicker base...... it looks like a shorty now
Old Oct 12, 2005 | 06:52 AM
anjapower's Avatar
disconnect your waste gate actuator...35 psi of boost mang.
Old Oct 12, 2005 | 06:53 AM
shimla's Avatar
pls explain further...thanks!!
Old Oct 12, 2005 | 07:09 AM
EVORyan's Avatar
Universal: WEIGHT REDUCTION!!! I have nothing left in my car now except for my shifter, stearing wheel, and driver's seat...no gauges b/c I just want to go as fast as possible, and no seat belt because I go too fast for it to matter!!!
Old Oct 12, 2005 | 07:15 AM
Killboy's Avatar
Good question, too bad everyone on here is a smart*ss.
Try searching for "DIY". (if the stupid search engine doesn't limit that too)
I know there is a restrictor in the clutch reservoir that can be removed for better response and stronger clamping.
Also I think some folks were removing a restrictor in the stock exhaust, but I replaced mine pretty quickly, so didn't study up much on that.
Old Oct 12, 2005 | 07:16 AM
matt55's Avatar
like this
https://www.evolutionm.net/forums/sh...hlight=muffler
Old Oct 12, 2005 | 07:19 AM
gsujeff55's Avatar
Tightening the wastegate actuator rod.
Clutch restrictor pill removal.
Old Oct 12, 2005 | 07:20 AM
fsugatorbait's Avatar
You can run a loop from the waste gate actuator to the turbo nipple to get rid of boost taper. You can crush your BOV for it to hold more psi. Run 15psi in your tires to get rid of unsprung weight. Take your air box out and go filterless. If I think of anymore, ill let you know.
