Bone stock IX goes 12.89
Old Oct 21, 2005 | 03:50 PM
  #181
Wicked's Avatar
Again running race gas will do nothing unless all evo's come from the factory knocking and pulling timing all over the place... i can't believe what i'm hearing.
Old Oct 21, 2005 | 04:03 PM
  #182
02MaximizedVQ's Avatar
True. And it is irrelevant what he thought the 100 octane was going to do to his car. Emprical data is the only merchant of truth in this argument and there is none so far. You can hope, pray, wish and believe all day long that putting 100 octane in the tank is going to get you another .1 second of your ETs but until you have a way to monitor timing you have no idea.
I think we will see more 12.8X passes as the 06's become more available.
Every year when a newer version of the same thing comes out there is a stuggle between early model owners and current model owners over which version is faster stock. We went through this ad nauseum on Maxima.org when the VQ35 came out.
Old Oct 21, 2005 | 04:28 PM
  #183
strikethree's Avatar
Originally Posted by GREDDY
Why don't you guys go back to the track and run it with 91, 93, 94 or whatever octane that's available to regular Joe at the regular Joe pump to shut people up? I probably wouldn't consider 100 octane stock. You will see a little more power in the upper rpm's with 100 octane fuel compared to say 91 octane fuel.
um... you do realize that octane is not a measure of power.
"The octane value of a fuel is an empirical measure of its ability to resist detonation and, to a limited extent, preignition. Technically, octane ratings measure a fuel's ability to resist the spontaneous ignition of unburnt end-gases under controlled test conditions." taken from here: http://www.prime-mover.org/Engines/G...es/octane.html
there is no power difference between running 91,93,94,100, etc octane fuel. where you get the power is from more agressive timing/more boost due to the lower chance of knocking/detonation.
since he said nothing about increasing boost, changing timing, etc, it is safe to say that those times were stock... assuming he has a time slip to show us.
strike
Old Oct 21, 2005 | 04:29 PM
  #184
gsujeff55's Avatar
Originally Posted by inariv5573
My thoughts exactly Warrtalon. 100 octane is rare. When cars are rolled off the factory plants, they are given to the consumer with 91-94 octane in mind. But I do see what others are saying. 100 octane has no bearing on making a car not stock. But it is something out of the ordinary. So I consider it a power adder, kind of like nitrous, of course not as potent.
so, you think they run the car off the line with the car not running 'optimal' with the normal pump fuel around the US? HELL NO.
Old Oct 21, 2005 | 04:52 PM
  #185
vtecwrecker's Avatar
Originally Posted by NapervilleEVO
coincedence, no. jealousy, yes.
actually its not jealousy at all for me its more of a...." man im glad i dont have to buy the evo 9 now cuz im not missin out on much" kind of thing!
Old Oct 21, 2005 | 04:55 PM
  #186
RaNGVR-4's Avatar
i just have to add this because you all are turning the evom forums into the freaking SRT-4 forums. octane is a KNOCK INDEX. the higher the octane the more resistnt it is to knock. wanna know why? higher octane burns slower. unless you can take advantage of the higher octane (up the boost or advance the timing) higher octane can actually HURT your power due to the fact that it burns slower. if you gain power buy just dumping high octane in your car then your tuning is messed up. either you have your timing too far advanced and it knocks on pump gas and not on high octane, or your car knocking on pump from the factory. and to prove this, in MY CAR, running the same boost and timing with 91 vs 100, i loose on average .1-.2. but if i advance the timing or up the boost (or both) i can gain upwards of .4 seconds. and yes, ive tryed this. most of you evo guys have sooooooo much to learn it hurts my head. i joined this site because i will be joining the ranks of evo owners sometime in the future, but damn, some of you guys give all the smart people bad reps. my advice to all of you who just drive your evo and know nothuing about the way it works, or any car works for that matter is search the internet to learn some before you talk out of your buttholes. theres a wealth of knowlege out there, and the people who know a thing or two only did it by wanting to learn, so GET TO IT and stop posting rubbish.
Old Oct 21, 2005 | 04:58 PM
  #187
Smoothgangsta's Avatar
Haterz???$$@@@@!
HAHA
Post your timeslip LAMER!
Old Oct 21, 2005 | 05:09 PM
  #188
evil8's Avatar
You are only going by theory here but we live in the real world. Even stock the Evo has 2 maps one more agressive than the other. Many of the 91 octane gas cars in the west coast end up on the less aggressive map and even some of the 93-94 octane cars will end up on that map when they get a bad batch of pump gas. And I've seen boost on stock Evos anywhere from 16 to 22 psi peak so not all stock evos are equal in peak boost and boost curve. The boost obviously can have effect on knock and timing pulled. So having 100 octane in the tank can help some cars even stock, even if it is just there to prevent any possible chance of knock and give you a more consistent running car.
Old Oct 21, 2005 | 05:20 PM
  #189
RaNGVR-4's Avatar
not necessarily true, mitsubishi ecu's have something called octane value reset. also, every evo has the same tune from the factory. if, for some reason the ecu sees knock, then yes, it will learn to not advance timing as much, only until the octane value is reset or the ecu is reset. in theory every car should behave the same. bad gas and things will throw that off. but people calling high octane a "mod" is absolutely retarded. if anything at all, higher octane is just letting the car do what its supposed to do stock
Old Oct 21, 2005 | 05:23 PM
  #190
EVIL_EVO_VIII's Avatar
This has turned out to be the players haters ball
Old Oct 21, 2005 | 05:25 PM
  #191
ModenaTwinTurbo's Avatar
dont know how late i am in this thread, i only read scarcely up until the 5th page, and i just would like to congradulate anyone who has been able to drive a stock 4g63 powerd car to a 12 second time slip, thats great. and to me 100 octane is not a mod due to the fact that there might be an instance where you might only be able to put 100 octane unleaded in your car. and you can deffinitely drive it in the streets no problem. furthermore there are cars that come from the factory with a fuel system that support ethanol fuel suply. and thats alchy.
i like the evo 9 theres a black one at shelton mitsubishi for anyone from the southern ct area that would like to check one out. it looks very good.
Old Oct 21, 2005 | 05:26 PM
  #192
Sinister Subaru's Avatar
This thread has turned to sh*t. I'm out.
Old Oct 21, 2005 | 05:28 PM
  #193
evil8's Avatar
fatheroftheevo, you should practice what you preach and learn some stuff before you post. What I posted is true and evo specific. And fyi your galant has much more in common with dsm's than evo so I would hardly call it father of the evo.
Old Oct 21, 2005 | 05:45 PM
  #194
EvoTio's Avatar
I also agree with you on this octane issue. Our Evos run so damn rich completely stock that it can't take advantage of the higher octane unless you tune for it. I was running 13.80's @ 100 MPH bone stock on 91 octane with my 03. I later added 5 gallons of 100 octane to see if I would pick up anything and you know what, I ran slower! I ran 14.10's to 14.30's at around 97-98 MPH. The car just felt doggy. I returned the following week on 91 octane and ran 13.80's @ 100 MPH again. If I had a way of leaning out the A/F ratios, I definitely would have gone faster on 100 octane. I'll give props to this guy who ran 12.80's @ 107 MPH, that's a heck of a trap speed with no real mods. I still think he would have run some good times on pump gas if tried it before adding the 100 octane. We'll just have to wait and see what the other IX's run at the track.
Old Oct 21, 2005 | 06:02 PM
  #195
SiCKlEyWiKeD's Avatar
my best 60" is 1.88 with the limiter but i avg 1.9's
