Does the wing?
Old Nov 9, 2005 | 12:55 PM
mike1023's Avatar
Does the wing?
ok i wanted to know from you guys. does the wing slow you down becasue of down force. becasue i know rs is faster then the reg evo. but if wing has more down force. will it mean give better handling and if so if take if off will you really tell the diff in it all. plz let me know thanks. and does anyone who have there wing off know how much it weights. thnaks
Old Nov 9, 2005 | 01:02 PM
walkedu's Avatar
I took mine off and could FOR SURE feel a difference but only at high speeds. I like it off anyway. Looks cleaner and less ricey IMO.
Old Nov 9, 2005 | 01:05 PM
mike1023's Avatar
high speed like 100mph up or somthing. and what does it free like like the back end going all over. or what. and do you notice is it faster or slower the car. feel like more drag on the car or less. is less then should be faster but then the back end will go out on you.
Old Nov 9, 2005 | 01:09 PM
LimPShoT's Avatar
RS is faster than gsr because of less weight -ac, stereo, abs, alum hood.
Old Nov 9, 2005 | 01:12 PM
mike1023's Avatar
ya ok understand. but im ully gutting my gsr as we talk. and wanted to know if wing does anything but keep back end down more. and if so i think i would want becasue im making it a road race car. and on that note if so i will get a CF trunk with the holes for the wing.
walkedu's Avatar
With my wing off doing about 80 on a clear day, it feels fine. It's on windy days it feels like the back end is moving around. Like it's on ice or something? No difference in speed though. The weight of the wing is next to nothing. At low speeds (about 65 or less IMO), the wing is good for nothing but making people want to race you.
Old Nov 9, 2005 | 01:23 PM
Happy Madison's Avatar
personally, i wouldn't do the CF trunk, or any other weight reduction to the back end. the car is already nose-heavy...
Old Nov 9, 2005 | 01:28 PM
mike1023's Avatar
yes i know what you mean. but also think of this im taking ac out and butting small batt in. also air intake with after market save 10lb so will be about say front end can say 30+20+10=60 so thats more then the trunk. so its a if thing. also with full coilovers and sway bars can help dispres the weight.
Nez136's Avatar
there are soooo many misconceptions about the RS, GSR, MR. why don't people just do the research??? is that so hard to use the search function?
Old Nov 9, 2005 | 01:33 PM
mike1023's Avatar
why if so easy why not just post the link to were the forum is then gosh.
Old Nov 9, 2005 | 01:36 PM
Ludikraut's Avatar
Yes, the wing adds noticeable downforce, which will limit your topspeed, but only if you've gotten rid of the speed limiter in your ECU (otherwise either way you'll hit the limiter). If you want the best of both worlds, then get yourself a rear undertray (like the kind Vishnu was selling) and ditch the wing. That will give you better stability (no "parachute" effect from the rear bumper) and slightly more downforce (though obviously not as much as with the wing).
Ultimately aerodynamics always end up being a compromise between stability (more downforce, more drag), and speed (less downforce, less drag).
l8r)
Turbo Meg's Avatar
So true!
Old Nov 9, 2005 | 01:41 PM
8o8style's Avatar
i agree with turbo meg...
Old Nov 9, 2005 | 01:45 PM
drivethrufinch3's Avatar
I have an evo 7 wing on my Lancer es and i took it off one time, and purposly went fast to see if i could tell a diff, i did notice like it was less stable (not wrecklessly unstable) but less stable at high speeds like 85+
Old Nov 9, 2005 | 01:53 PM
1.8t's Avatar
Bingo.
