Test pipe + High flow cat
Old Nov 12, 2005 | 02:38 PM
Wicked Evo's Avatar
Hey guys, I recently went to court to fight my exhaust ticket, because my exhaust was to loud, they never checked if i was catless, but I won the appeal, my only problem is i have a helix test pipe, and helix high flow cat in my basement, is there any way at all that i can make the test pipe, look like a real cat, but what's really under the cover is a test pipe?
I know I can probley gut the high flow cat, but it wouldn't be the same.
Old Nov 12, 2005 | 02:40 PM
justchil's Avatar
You could weld the casing of the cat onto the test pipe so it looks like a cat.. but I would recommend a muffler like Magnaflow if you want to quiet it down...
Old Nov 12, 2005 | 02:43 PM
Wicked Evo's Avatar
Well the exhuast sounds like it's stock untill you open her up, that's why i got pulled over, where would i get the cat cover to weld onto the testpipe.
Old Nov 12, 2005 | 02:56 PM
Turbo Meg's Avatar
Can't help on what to do, but it seems like alot of work. I run a test pipe on my Evo and GN never had a problem with the cops. Where did you get the ticket!
Old Nov 12, 2005 | 05:19 PM
BuLocal's Avatar
These guys used to sell a shell that could be tacked onto a test pipe, not sure if they still do. I would contact them because when they did it wasn't listed on their website. http://www.ultimate-racing.com/
Old Nov 12, 2005 | 10:07 PM
KevOVIII's Avatar
Buschur Racing did it for me. They had to cut open a cat to weld the shields over a test pipe.
Old Nov 13, 2005 | 12:52 AM
MitsuJoe's Avatar
If you get a 3" HF Ebay cat it is actually 3" ID and most piping is 3" OD and thus this will fit into another, then you weld this straight piece through the cat and then you have it, a testpipe with a shell. They will never know the difference unless they unbolt the cat and inspect, which will take a court order to do. Knocking out the cat material takes long screwdrivers and a hammer but it is very possible. Any "undertsanding" mufflershop will weld this for you but not actually install it on to the car.
Old Nov 13, 2005 | 05:23 PM
EVOla_VIRUS's Avatar
Get the RRE rally cat....cant go wrong!
Old Nov 13, 2005 | 06:55 PM
trialsallday's Avatar
remember when you came over, well its good that we didnt try welding cuz i forgot i dont have welding wire for stainless steel. ive never welded stainless in my life, just plain raw steel, from what i understand stainless is a whole other story
Old Nov 13, 2005 | 10:10 PM
Jakeg97's Avatar
+1
Old Nov 14, 2005 | 05:40 AM
ru4real's Avatar
Replace the test pipe with the high-flow cat. You won't feel the difference.
chris4b11t
Nov 21, 2013 06:16 AM
kreionic
May 30, 2006 09:16 PM
Jim_Patterson
Dec 19, 2005 12:38 PM
dsevo
Oct 5, 2005 11:29 AM
chapter8
23
Jan 7, 2005 09:33 PM
