Truth Squad: 2005 TSBs and Recall
Old Mar 14, 2007 | 08:46 AM
  #46
Warrtalon's Avatar
Just keep trying. I found all this by going there and following the directions. It's pretty self-explanatory.
I just went and tried it - got right to the 2006 Evo TSBs - there are 2 so far. It's easy to use - look it up by vehicle.
Old Mar 14, 2007 | 08:49 AM
  #47
dudical26's Avatar
I think you gave me the wrong URL, was this the site you were referring to?
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
Old Mar 14, 2007 | 08:50 AM
  #48
Warrtalon's Avatar
The full/proper site link is in the first post.
Old Mar 14, 2007 | 08:51 AM
  #49
kreionic's Avatar
Its the right link. There are no recalls for 06 and like warrtalon said there are 2 tsb
Make : MITSUBISHI Model : LANCER EVO Year : 2006
Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC.
Service Bulletin Num : 0613008 Date of Bulletin: APR 01, 2006
NHTSA Item Number: 10019919
Component: ELECTRICAL SYSTEM
Check to Request Research. Submit below. Get Summary
Service Bulletin Num : 0613005 Date of Bulletin: APR 01, 2006
NHTSA Item Number: 10019921
Component: ENGINE AND ENGINE COOLING:ENGINE
Old Mar 14, 2007 | 08:52 AM
  #50
dudical26's Avatar
ok I found the two TSB. I am currently experiencing a grind in 5th grear and there is no TSB for this for 2006 cars. Am I still covered under the TSB for this issue for earlier model years?
Old Mar 14, 2007 | 08:55 AM
  #51
Warrtalon's Avatar
No, the TSBs are year-specific, but a TSB is just a TSB. It doesn't mean you can't also get a grind fixed for your 06. You should take it to the dealer, have them replicate the grind, then they should fix it no questions asked, although it wouldn't be surprising if they blame your mods.
Old Mar 14, 2007 | 08:57 AM
  #52
dudical26's Avatar
Yea, I'm pretty sure they will blame my mods for the grind. Is there any special approach or tactics I can pursue which can help me to get this fixed under warranty?
Old Mar 14, 2007 | 08:59 AM
  #53
kreionic's Avatar
For a better chance of them fixing it swap all your parts back to stock. I now its a pain but it might be worth it for the fix
Old Mar 14, 2007 | 09:02 AM
  #54
Warrtalon's Avatar
I would print out the 03 TSB (posted in the 03 TSB thread) and take it in so that they realize it's a common problem with all Evos, whether Mitsu recognizes it on 04-06s or not.
Old Mar 14, 2007 | 09:05 AM
  #55
dudical26's Avatar
Swapping everything back should not be too big a deal, aside from the 02 housing which I might just leave on. Although it would be REALLY annoying to swap it all back and have them still not cover it under warranty.
The other thing is that I am going to swap my 4th gear with a 4th gear from an Evo 8. If they replace my 5th gear under warranty I still need to swap my 4th. I was thinking I could try and talk to the mechanic who was going to work on the car and see If I can sorta bribe him to do the swap if I give him the parts. Although with the changing of 4th and the grinding in 5th it might make sense to just pay for it myself. I would probably put in a clutch at the same time also.
Old Mar 14, 2007 | 10:19 AM
  #56
Chemwarrior's Avatar
Thanks for this Warr. I've bookmarked it for future reference. Hopefully I will never have to use it. As far as going to the dealership and worrying about them voiding your warranty I will always put my stock parts back on. I don't want that hassle from them and spending a few hours putting all the stock parts back on is well worth the peace of mind.
Old Mar 14, 2007 | 02:14 PM
  #57
Dr.Sound's Avatar
just called my dealer. they ran my vin and turns out my car WAS one of the ones affected by the recal.
the hose was replaced prior to delivery to me. when i bought the car the dealer never mentioned any work done on the car......
i guess they just replaced it while the car was sitting on the lot waiting to be sold.
THANKS WARR.
Old Mar 14, 2007 | 03:10 PM
  #58
4TUN8's Avatar
truth squad lol I forgot all about it.
Old Mar 15, 2007 | 02:28 PM
  #59
Jakeg97's Avatar
me 2. where can i find that avatar- lol
Old Mar 15, 2007 | 09:43 PM
  #60
barneyb's Avatar
Originally Posted by thekuai
what does it mean when it says "MITSUBISHI TECH TALK. *TT " next to the tsb?
Its a news letter put out for the shop guys in an effort to keep them up to speed about new vehicles coming out. The TSB stuff will often appear there first.
BTW, the best thing to do is order the TSBs from the government web site. They say that there will be a charge that you agree to pay ahead of time without knowing the amount. I ordered four TSB's and when they arrived the form letter said that they were free. So, I'm guessing that if the volume you order isn't too much you get the stuff free.
The information is run off on a bad copier so they aren't super legible.
