Grinding while braking???
Old Dec 18, 2005 | 04:25 PM
evolucion's Avatar
Just got back from playing with the snow for the first time. While I was braking, the car sounded like it's grinding and it wants to stall sometime. I have no problem shifting through all the gear, so it can't be the transmission or could it be. I only tried launching a few time that's it. The grinding sounded like it's coming from around the downpipe area. I had a piece of wood stuck down by the downpipe and the sway bar once. I inspected the area and found nothing but to pull that piece of wood out. This is the first time that it happen so I'm .... Scare
Old Dec 18, 2005 | 04:27 PM
stevo_mr's Avatar
Grinding while brakes are applied or still grinding without brakes applied
Old Dec 18, 2005 | 04:31 PM
evolucion's Avatar
Old Dec 18, 2005 | 04:34 PM
raiceboi697's Avatar
its your ABS activating. mine does the same thing when i break hard
Old Dec 18, 2005 | 04:35 PM
stevo_mr's Avatar
Do you have any rust spots on the rotors? Check for rocks stuck between the rotors and calipers. If it sat for a while before you drove it after the snow sometimes a little rust will build up and it sounds weird for a couple of stops but it sounds like yours happens all the time. Sorry know knowledge about the trans or diffs.
Old Dec 18, 2005 | 04:36 PM
evolucion's Avatar
Weird
Old Dec 18, 2005 | 04:37 PM
stevo_mr's Avatar
Now I see were you braking in the snow like the previous post said. If so 99% sure it was the ABS
Old Dec 18, 2005 | 04:42 PM
evolucion's Avatar
I hope so thanx for the info guys
Old Dec 18, 2005 | 05:15 PM
Zemo's Avatar
yup, ABS. mine did that today when I was testing how hard I could break in the snow.
Old Dec 18, 2005 | 05:18 PM
chaotichoax's Avatar
happens on my STi sometimes in the snow good to know it's the ABS haha I know that exact sound kind of scary
Old Dec 18, 2005 | 06:34 PM
evolucion's Avatar
For real, I thought I landed on a piece of broken branch from the tree or something.
Old Dec 18, 2005 | 06:41 PM
RalliArtEvoVIII's Avatar
heard it all the time on my evo esp when stupid cars come flying outta nowhere and brembos have to come into play
