Hiding a boost controller.
Old Feb 26, 2007 | 01:02 PM
SinCityVIIIMR's Avatar
Originally Posted by Evolution[OH]
Well, the game is hide it or take it off..... is so screwed up in the had they will say that your brembo's are pealing because of the intake. Or slotted rotors cause your tranny to blow up!!!! So the game is hide it or take it off, cause will void you warranty
LOL, so true. I am going through an arguement right now about why my calipers are peeling. Luckily they didn't blame it on the intake, but they did blame it on brake fluid even though there is no peeling whatsoever around the bleeder valves or brake line.
To the original poster... Like the other's say just put it back to stock when it goes to the dealer.
Old Feb 26, 2007 | 01:33 PM
XK120's Avatar
Have you considered using the stock BCS? Flashes like the Jestr M1 flash can control boost very effectively using the stock boost control solenoid. That being said, you won't gain as much power as an MBC would net you but it would be safer as far as the stealship goes. Also if you do get an MBC consider the Hallman instead of the Forge.
Old Feb 26, 2007 | 01:35 PM
fxyxixe's Avatar
Does anyone know of a place to buy the stock hose setups?
I want to be able to take off my MBC for warranty purposes but I don't have the stock hose setup..
Old Feb 26, 2007 | 01:40 PM
newbieEVO8's Avatar
^ the dealership.
Old Feb 26, 2007 | 01:51 PM
mdsevo06's Avatar
And a Flash can be detected by the Dealer if they look. I have a bone stock IX with 18,xxx, never raced it and changed the oil with Mobil one and factory filter every 3,000. My Rod Bearing and Main Bearing had Rod knock symptoms, took it to the dealer and they concurred. First thing they did, was check for any mods, including checking the ECU for a flash. I had all my receipts and paper work, and was fully covered with new Rod bearings and Crank Bearings, along with Rod bolts. Point being, you better be able to return it to complete stock if you have any warrenty work done.
Old Feb 26, 2007 | 02:15 PM
XK120's Avatar
you can always flash back to stock
Old Apr 1, 2007 | 08:23 AM
mdsevo06's Avatar
Changing back to stock still chages the Checksum, dealer can still see that you have flashed the ECU.
Old Apr 1, 2007 | 09:03 PM
ixsaves13's Avatar
you should call the dealership and talk to the tech guys. ask questions on what mods would be acceptable and leave your name out. This would give you an idea if you don't want to void warranty.
Old Apr 1, 2007 | 09:07 PM
Brian's Avatar
omg I wuz wondering da same ting.
Old Apr 1, 2007 | 09:14 PM
evovin's Avatar
^ +1
dogginred90
Outlander Sport
22
Mar 26, 2018 06:46 AM
Newby81
Toronto Lancer Club
May 3, 2016 04:23 PM
a4rontran
May 20, 2011 07:41 AM
ominous24
Nov 16, 2006 06:15 PM
PurgeIt
25
Aug 24, 2006 04:02 AM
