My dyno numbers
Old Mar 14, 2006 | 06:12 PM
Evo VIII 4G63's Avatar
My dyno numbers
here it is
Old Mar 14, 2006 | 06:14 PM
Ph3n1x's Avatar
U expect peopel to read a thumbnail?
Old Mar 14, 2006 | 06:15 PM
how do you make it bigger
32 psi daily's Avatar
i see blue and green.
Old Mar 14, 2006 | 06:23 PM
Stinkapuss's Avatar
Did you mess with the cam gear settings on the dyno? What did you end up with if you did?
Old Mar 14, 2006 | 06:26 PM
nope cam gears are zero/ zero
Old Mar 14, 2006 | 06:31 PM
just click on the picture I made it a little bigger
Old Mar 14, 2006 | 06:41 PM
bluebanana23's Avatar
what do other 05's dyno at with this dyno? Numbers seem low but since you don't have a tune...
Old Mar 14, 2006 | 06:43 PM
RazorLab's Avatar
What are you using to tune? Your HP curve shouldn't drop like that at 5800, espically with 272s.
Compare to these curves: http://tinyurl.com/jmmm3
Old Mar 14, 2006 | 06:52 PM
sean ivey tuned my car
Old Mar 14, 2006 | 06:58 PM
is that my bov leaking that would cause that
Old Mar 14, 2006 | 07:10 PM
the owl's Avatar
it seems low but then my eyes my be playing tricks on me
Old Mar 14, 2006 | 07:34 PM
steinvb12's Avatar
The Forge BOV won't leak at that pressure. I would say it's pretty normal numbers, maybe even a little high for a Mustang dyno. He should see about 330whp on a dynojet dyno.
Does it "feel" good, because it should. Just out of curiosity, what psi is the tune for? 20? 21?
Also, I am from Reading, which isn't far from A-town. I hear there is a small meet at Red Robin in A-town this weekend. I might be up for it if the weather ok. PM me if you want more details.
Old Mar 14, 2006 | 08:04 PM
DynoFlash's Avatar
Sean does a great job and those numbers look very customary with your mods on a mustang dyno which do read very low - enjoy
Old Mar 14, 2006 | 08:39 PM
Dropspeed's Avatar
This is my sheet from a Mustang Dyno
Mods are DC header, DC downpipe, Thermal Exhaust, AMS intercooler, Walbro 255 pump, Apex Filter, TurboTrix Mail in flash. AMS MBC set a 21PSI
No Cams (stock), 93 Octane:
