comp 280 cam questions
Old Mar 20, 2006 | 04:59 PM
boosterclubevo's Avatar
I just recieved comp 280 cams and the specs dont say 280 on them anywhere. They do say 265 and 264.So I thought they sent me the wrong cams I called them and they assured me that they were right. Does anybody else know what Im talking about or are they just bsing me? also what valve springs would be best?
Old Mar 20, 2006 | 05:09 PM
ries's Avatar
dont worry you got the right cams
I thought the same thing when I got mine but if you compare the ID # on the spec sheet to the web site they match
hope this helps
Old Mar 20, 2006 | 05:13 PM
hope this helps
Helps alot thanks. What valve springs are u runnin?
Old Mar 20, 2006 | 05:59 PM
Zeus's Avatar
It depends on at what lift you you want to measure the duration...
Old Mar 20, 2006 | 06:03 PM
Dingo7's Avatar
bump
Old Mar 21, 2006 | 03:39 PM
One Wicked EVO's Avatar
that happened to me too but i sent mine back lets see what the new ones say!!
Old Mar 21, 2006 | 04:39 PM
swordfish's Avatar
They will say the same thing. Like Zues said, it's all about the lift at which the duration is measured. Measure an HKS 280 at the same lift the Comp's are measured at and they wont be 280 either.
jeff
Old Mar 21, 2006 | 07:24 PM
bigchris2000's Avatar
Funny thing I got mine today and they said the same thing. If it says 119301 and 119302 the cams are 280 I called also and if you look on the forced performance
website on the specs on the 280s it matches the cam sheet the comes with the cams.
Old Mar 21, 2006 | 07:28 PM
staatz's Avatar
Hmm, I got the 280 cams put in yesterday at TurboTrix and I promise you you WON'T reget it. They are absolutely sick sounding and give you so much more top end=D
Old Mar 21, 2006 | 07:38 PM
How is the bottom end? is it better all around? I am getting mine put in this weekend. thanks
Old Mar 21, 2006 | 07:44 PM
ibanez_926's Avatar
bump for if valvesprings and retainers are required. I will be ordering some from forcedperformance soon. I think im gonna go with the 270's tho
Old Mar 22, 2006 | 03:26 PM
trinydex's Avatar
where did you guys get the idea to get these cams?
Old Aug 25, 2006 | 03:16 AM
ONRAILS's Avatar
are you guys running springs and retainers also?
Old Aug 25, 2006 | 05:52 AM
TurbotrixRacing's Avatar
you don't need springs and retainers to run 280's.. we have installed 280's on hundreds of cars without any upgraded internals. the comp 280's won't say "280/280" on the box.. the part numbers are:
119-301-8I for the Intake cam
119-302-8E for the Exhaust cam
-Mike
Old Aug 31, 2006 | 01:27 PM
Turbo Kyle's Avatar
Are the comp cams a good choice? What are the Pros/Cons of HKS, Comp, Revolver, ect.
Thanks!
