Car went BOOM today........
Old Mar 31, 2006 | 07:30 PM
revvin9k's Avatar
Originally Posted by Danny23
first check the ic pipes, if theyre alright then i would tow it back. if you want to get some sleep tonight just go check it now with a flashlight and get it over with. if its the icp then have a good nights sleep and put it back on in the mornig. if it isnt the icp then go rent some movies cause your gonna be up all night
Since I got the AMS IC, it's kinda difficult to see the lower IC pipe, or even access it at that. My S2000 may have been a torqueless wonder, but damn was it reliable.
Old Mar 31, 2006 | 07:32 PM
Danny23's Avatar
**** happens, good luck
Old Mar 31, 2006 | 07:33 PM
TarmacBlackEvo8's Avatar
it's probably one of the intercooler pipes popping off. Get some t-bolts it will help them stay on.
Old Mar 31, 2006 | 07:40 PM
lookEVO's Avatar
Originally Posted by revvin9k
"Beam me up Scotty, no intelligent life form here." WTF, does that mean? ^^^^
see sig, that is all
Old Mar 31, 2006 | 07:41 PM
deffro's Avatar
Originally Posted by cityhugo
u will not be able to drive 30mph home if is the hose.
When mine came off I was able to get it to about 25-30 to limp home. Definitely wasn't able to get it much faster.
Old Mar 31, 2006 | 07:42 PM
alloyic_rs's Avatar
wouldnt yall think that before installing any sort of hard pipes (IC pipes, or exhaust) then you'd need some harder motor mounts?
i mean the engine moves around alot on those stock rubber mounts once you give it gas and start shifting, i would say that would have some impact on those pipes popping off like that, (assuming that it was your IC pipe that came off)
revvin9k's Avatar
Sorry man, no hard feelings. Just a real long and crappy night. Try explaining to your wife why your car is fu*ked up after you just spet $4k on it. Not an easy thing to do by all means.
Old Mar 31, 2006 | 07:44 PM
lookEVO's Avatar
i got blamed by mine for my accident, she had to come pick me up at 2 in the morning, so you are talking money to Bill Gates bro but i do understand your dilemma. use hairspray on the hoses and tclamps
gatorade's Avatar
Things are going to go wrong when modifiying cars. Things aren't perfect, might wanna go back to AMS get it all sorted out. Good luck man, **** happens.
Old Mar 31, 2006 | 07:45 PM
Kerr's Avatar
Fomer Vendor
I have had the IC piping blow off on me in 2 different spots. The first was at the thottle body, and the cel came on, car ran like crap. Second was at a boot about a foot and a half away from the TB, car ran, no codes, just no boost. So I would say check the boot at the TB, since you said you had to limp home.
Old Mar 31, 2006 | 07:48 PM
revvin9k's Avatar
I checked all the piping except for the lower one which is not very accessible, especially when there is water on the ground. I'm just gonna hope for the better and hope it's an IC pipe. If not, i'll take the loss and sell her. Wow, only 9500 miles too, on an 04.
Old Mar 31, 2006 | 08:06 PM
iLLiVo's Avatar
are you even hitting boost? if its an ic pipe you wouldnt be able to create boost if its completely popped off.
Old Mar 31, 2006 | 08:09 PM
revvin9k's Avatar
I limped the car home, I was'nt even attempting to see if I had boost with the SES light on and the way it was running.
Old Mar 31, 2006 | 08:14 PM
Vroompsh's Avatar
Think about it though, you came in with lower boost and left with a lot more...the intercooler hose was probably on tight enough for whatever psi u were running beforehand
blkAMSevo8's Avatar
ive had that happen to mine, but i was on a the highway pushing 27 psi in 4th on a 35r, and i hear exactly what your talking about, pulled over, me and my friend checked it out, and it was the pipe coming off, very easy to see, just go check?
