Mini Battery
Old Apr 2, 2006 | 07:15 PM
rollmodel's Avatar
Mini Battery
Here is a little info/pics of my mini batter project.
I made a cardboard template after I removed the stock battery (see bottom of post for link to removing battery). After that I just went to town cutting - here is what I came up with.
Brand Name companies batteries ~ $195 - $260
My project
Mini battery (odyssey 680mj) $85 (ebay)
Stainless tray - free
Aluminum tie down - free
threaded tie down rods (cut down stock) - free
Total cost (for those with arthimatic skill difficulties) - $85
Stock
Testing the battery for a day to make sure it worked (notice the plastic spacers on the tie downs - they were too long, that is why I cut them down later)
This is the finished piece
So, now the upper intercooler pipe looks kind of wierd, but it will be changed with another 'budget' upgrade.
All and all the finished product came out great. This was not meant to be a 'cheap' project and for those who don't have the stainless and/or aluminum laying around this would have cost about 100 bucks.
For anyone looking for a write up of how to remove the battery Nisei engineering did a semi good one. They failed to mention (at least from what I noticed) that wires are connected to the battery tray and that it may be easier to remove the filter to get to the clips below. But other than that its a good write up.
Nisei Engineering mini battery install
I am not sure if this will fit with the stock airbox. I did not use that as a requirement when I made it because I have the BR filter installed.
Old Apr 2, 2006 | 08:19 PM
KevinD's Avatar
a hundred dollars? haha raw materials for that will cost nowhere near 100 dollars. even from the most expensive material supply i know of (mcmaster carr) you can get a 1/4x2x6 6061 aluminum bar for 15 dollars, and a 12x12x.04 stainless sheet for the bottom for 10 dollars. two bolts with nuts, 5 dollars tops. total cost, about 30 dollars...
otherwise, looks good and props to the DIY.
Old Apr 2, 2006 | 08:25 PM
Links0000's Avatar
I think he meant $100 including the battery
Old Apr 2, 2006 | 08:36 PM
Str8Ryda's Avatar
Very nice!
Looks just as good as Buschurs tray. So you say it would have cost $15 in additional materials?
Old Apr 2, 2006 | 08:45 PM
fromWRXtoEVO's Avatar
I found out 2 weeks after I bought my battery kit that I can get the same battery in town(just the battery alone) for just around $65.
Name of the shop :Battery plus
Carlos
Old Apr 2, 2006 | 08:47 PM
gt35R's Avatar
thats the same battery I got in my evo !! good call!
Old Apr 3, 2006 | 05:01 AM
rollmodel's Avatar
Exactly, $100 bucks total (assuming you paid the $85 for the same battery + ~$15 material).
There is minimal material required (just the tray and tie down). The rest can be reused from stock (bolts and nuts). It will just take time to make it - that is it.
You can get less expensive batteries, but this was one of the larger ones offered by odyssey without going to a larger size case that will get in the way of my future intercooler pipe.
Thanks for the compliments guys.
Old Apr 3, 2006 | 06:51 AM
LA EVO 8's Avatar
Old Jul 22, 2007 | 07:53 PM
IAmADirtDude's Avatar
dood i wish i saw this last week. i'm a welder and mechanic by trade and i just ordered the kit to save time thinking it would be easier. i thought i was getting that billet one they sell. i didnt pay attention on my order that mini battery kit isn't anything special, coulda atleast engraved buschur on it man!
Old Jul 22, 2007 | 10:36 PM
CheesyEVO's Avatar
That looks near perfect...good job and thanks for the info.
Is that an Oddessy PC680?
Old Jul 22, 2007 | 10:37 PM
CheesyEVO's Avatar
Can you trace out the thing and post a pattern? That would rock!
Old Jul 22, 2007 | 11:36 PM
Evoryder's Avatar
battery is listed at 100bux w/ shipping...where'd u get the negative a positive terminals for cars? You got it from the same ebay vendor for few dollars more?
Old Jul 23, 2007 | 02:47 PM
Jakeg97's Avatar
looks good
