front license plate
Old Apr 19, 2006 | 09:48 AM
kreionic's Avatar
Question front license plate
I live in Maryland and got some tickets for no front plate as alot of evo owners have. Is there a way to mount the plate without drilling in the bumper. Right now I am uing zip ties but it is in the center of the intercooler. Will that restrict are and make the intercooler to warm.
Old Apr 19, 2006 | 09:51 AM
Torre from Va.'s Avatar
Yikes, I saw a Camaro with one literally under the front bumper, sooooo !
Old Apr 19, 2006 | 10:24 AM
dayf's Avatar
Yes that will block air flow to the intercooler.
If I'm not mistaken, the evo 8 had a spot to put in a bracket to the right of the air dam without having to drill. No such luck on my new one!
Old Apr 19, 2006 | 10:54 AM
EnJaNir's Avatar
It says you drive an 8. You do NOT need to drill any holes to mount the front license plate bracket. Yes the instructions tell you to drill 1 hole, however, it is not necessary. There are 2 hard mounting locations that you can bolt to and if you use a piece of double sided tape on the location where you are supposed to drill the hole you will have no problems.
Old Apr 19, 2006 | 10:55 AM
dan628's Avatar
yeah use the bracket that came with the car, you use some bolts that are already there are I didn't drill. And it doesn't block the interceooler. If you cant find the bracket, mine was in the trunk in the side compartment opposite the windshield washer bottle.
Old Apr 19, 2006 | 05:00 PM
hillbilly8R's Avatar
I did the same thing after I seen the size of the hole to drill. I have had the double sided tape on the lower bracket as well. Works fine.
Old Apr 20, 2006 | 05:04 AM
yesevo's Avatar
me too..use 3m double side tape///
u have to heat the double side tape good with heat gun....
once u heat it and put the tape on to bumper and license plate.... it will never fall off...thats how i did on mine still holding good ......
if u dont heat it,, whats the point of using double tape??? trust me on this one! i do this for living.
Old May 19, 2006 | 04:07 PM
leaguestr's Avatar
Hey... I got the factory bracket from my '03 still sitting new in the plastic if you want it... Just cover the shipping plus 5 bucks and its your... let me know if you want it
leaguestr@yahoo.com
chris
Old May 19, 2006 | 06:43 PM
BMan's Avatar
I used the "pull tab" temporary double sided foam tape for mine. That way if I want to take it off, pull the tab, clean the spot, it's gone.
Old May 19, 2006 | 08:09 PM
sparky's Avatar
I dont like the look of the black plastic mounting frame that comes with the Evo 8 and I didnt like the idea of drilling the bumper either, and I tried the ziptied onto the mesh grill , but it looks dog awful....so I just used the metal bracketry that mounts the frame to the bumber but without the plastic thing and without drilling holes either.
Old May 19, 2006 | 08:23 PM
yesevo's Avatar
http://www.imagegravy.com/gallery/vi...gallery_id=104
i put mine using double side tape on bumper
Old May 20, 2006 | 08:50 AM
boostedwrx's Avatar
i get away with no plate in Seattle area... effin cops suck. Theyre busy writing you a retarded ticket while someone across the street is getting robbed.
RockLee989
Aug 9, 2017 02:56 PM
sadegh
Apr 13, 2017 08:39 AM
Evo_Goodness
Aug 7, 2016 09:52 AM
The hundreds.
16
Feb 4, 2012 11:47 AM
savagejay1
Northwest Region
Feb 23, 2011 12:09 AM
