stock cat-back removal & 3inch install questions
Old Apr 19, 2006 | 12:07 PM
Phizix's Avatar
stock cat-back removal & 3inch catback install questions
i've searched but couldn't find any answers. Does it matter if i remove the stock cat-back as one peice, or does it have to be done one section at a time?
Also, When installing a 3inch cat-back does it matter if i install the mid pipe first, then the muffler section? or is it better to install it as one unit? Thanks
Old Apr 19, 2006 | 12:10 PM
redza's Avatar
It depends I guess. I had a friend help me so it was easier and faster to remove the whole stock cat-back. Just unbolt from cat, unbolt the 2 bolts on the left rear hanger and the pull off the other two hangers. Same thing with the after market cat-back although I didn't fully tighten the midpipe to muffler section so it'll have some play and give you a chance to align everything properly first.
Old Apr 19, 2006 | 12:14 PM
Soon2BEVO's Avatar
You can do the whole thing at once, I actually think its easier. Start from the cat and move back to undo the muffler.
Old Apr 19, 2006 | 01:09 PM
sleet's Avatar
I removed everything at once, it's still all together in one peice sitting on my garage floor.
Old Apr 19, 2006 | 01:13 PM
PoorBoys's Avatar
It doesn't matter which way you do it. Do it however you think it is easier.
Old Apr 19, 2006 | 01:16 PM
adx's Avatar
adx
I removed mine as one piece, by myself. I jacked up the car from the front and unbolted everything.
Do know that the muffler is a big ***** to get off the mount.
Old Apr 19, 2006 | 01:17 PM
adx's Avatar
adx
Oh and about installation: I did it by bolting the DP in first, then working my way back. I used 3 sets of jackstands to hold everything up.
And a couple times, the wife had to hold things into posistion but nothing to diffcult.
Old Apr 19, 2006 | 02:43 PM
HIPSI9's Avatar
it wasnt bad on mine did it last night but i also did the DP and o2 housing, the o2 housing was a pain in the ......, but overall not that difficult
clip14
Jun 18, 2015 05:50 AM
Kreeker
Oct 12, 2014 07:08 PM
b4c346
Aug 21, 2014 08:09 PM
Silver09RA
26
Jul 24, 2014 10:05 PM
ace333
May 23, 2014 06:33 AM
