Walboro Fuel Pump
Old Apr 21, 2006 | 01:22 PM
SR20DE-T's Avatar
Walboro Fuel Pump
Do you need a install kit to install it or can you reuse the OEM kit.
Old Apr 21, 2006 | 01:26 PM
Compjoc's Avatar
nope, just reuse the OEM parts
Old Apr 21, 2006 | 01:27 PM
Warrtalon's Avatar
Don't need the kit, although it's not a bad idea if your car is old, since the o-ring and filter may be worn out a bit.
Old Apr 21, 2006 | 01:32 PM
sirloin1219's Avatar
just dont fill up your tank, liek the idot i am. do it with as little gas possible.
Old Apr 21, 2006 | 04:11 PM
Mortis's Avatar
Did mine when the little low fuel warning light came on. Had the kit, got it cheap, no problems.
Old Apr 21, 2006 | 04:12 PM
AlwaysinBoost's Avatar
there are several models out there... which is the best one to go with?
Old Apr 21, 2006 | 04:43 PM
gsrboi80's Avatar
Where is the best place to buy them?
Old Apr 21, 2006 | 04:46 PM
RED DEMON's Avatar
PM me for a place to get it for the cheapest price on EVOM, the seller told me not to post it up on public forums
I bought mine WITH an install kit for only 90 bucks!
Old Apr 22, 2006 | 06:03 AM
saiyanzzrage's Avatar
word
Old Apr 22, 2006 | 07:35 AM
andyjd's Avatar
anything else avaiable thats a bit quieter?
Old Apr 22, 2006 | 07:47 AM
WhiteEvo05's Avatar
Power Enterprise has one that is quite nice...good luck finding one. Does not flow quite as much as the Walbro, but it does not fall off nearly as fast with increasing pressure, either.
Old Apr 22, 2006 | 09:23 AM
Old Apr 22, 2006 | 09:28 AM
sleet's Avatar
I drove around for a little bit after the light went on to make sure there was NO gas in there, it can get very messey. Also I doubt you need the kit..
Old Apr 22, 2006 | 10:08 AM
4TUN8's Avatar
I'm not an automtive expert, and when I bought my winebro I certainly wasn't as good as I am now....and I still did it without the kit.
Hope that helps =)
Old Apr 22, 2006 | 12:10 PM
mybada's Avatar
I did mine w/o kit no problem at all!
Car runs much smoother at around 3800 where torque peaks.
But you will most likely lose a little bit of top end power until you do some sort of fuel adjustment.
ArchieBabes
May 20, 2008 08:24 PM
hacellular
Feb 24, 2007 05:34 AM
Batmann!
South Region
12
Sep 10, 2006 04:44 PM
MrBubbler
Nov 12, 2004 02:11 PM
mebefraggin
Aug 21, 2003 06:03 PM
