HELP!!! Transfer Case Fill PLUG
Old May 3, 2006 | 05:50 PM
LilyK's Avatar
I am having a tough time trying to take off the fill plug. I'm using a jack and I am trying my best to muscle off the plug. Looks like it's a lil rusted...I struck there for 1 hour trying to take them out.
Any suggestion? Please help me out!
Old May 3, 2006 | 06:00 PM
gsrboi80's Avatar
Eat your wheaties man.
Just kidding try putting a pipe on the end of your ratchet for more leverage.
Old May 3, 2006 | 06:01 PM
ibanez_926's Avatar
kroil
Old May 3, 2006 | 06:03 PM
sairaag's Avatar
use some PB blaster to break the rust also instead of trying to loosen the bolt try to tighten it first to break the rust inside then try to loosing it or use a braker pipe to help you with the leverage.
Old May 3, 2006 | 06:05 PM
EvilBlueEvo8's Avatar
carefull with that. i would use a breaker bar if you have one. much stronger than a wratchet. i used a wratchet once. i was having a hard time getting it off and the wratchet slipped. stripped part of the bolt. what a pain to get it off after that!
Old May 3, 2006 | 06:08 PM
BMan's Avatar
I just used the old flesh mallet to pop it loose.
Old May 3, 2006 | 06:09 PM
Mookie's Avatar
bump for breaker bar
Old May 3, 2006 | 06:17 PM
LilyK's Avatar
I'm gonna ask another question. I changed the tranny fluid last month. And I felt like i'm getting a lot worse gas mileage. I used BG Synroshift I. I pump til the fluid start coming back out.
Was it because I changed to 18 inches wheels. The lost in mpg is quite noticable. Amost 1/4 gas tank gone for 33 miles street driving!!!!...Not even driving it hard....Not in boost range. Stock ECU, no flash, only mod is Turbo back exhaust. !!!!!
Old May 3, 2006 | 06:19 PM
evillution's Avatar
+1000
Old May 3, 2006 | 06:20 PM
BMan's Avatar
I vote for the wheel change. What size tire?
LilyK's Avatar
235/40/18!! wow that the hack, i'm getting like 10 mpg for sake. The car runs normal though. wtf.
Old May 3, 2006 | 06:22 PM
gsrboi80's Avatar
Definately the wheels over the tranny fluid.
Old May 3, 2006 | 06:23 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
I find a good system with stuck bolts is to use pb blaster the hit the bold on the head with a hammer to shock it. The schock helps loosen it up. then try the blaster again if you have to. Theres always a way man
Old May 3, 2006 | 06:25 PM
LilyK's Avatar
Is this what you are talking about? thx man
http://www.sjdiscounttools.com/bst16pb.html
Old May 3, 2006 | 06:26 PM
BMan's Avatar
For wheel/tire comparing I always use this
http://www.miata.net/garage/tirecalcold.html
sorry for the ot.
yes breaker bar and flesh mallet.
