problem with car
Old May 30, 2006 | 07:41 PM
SubiEvolved's Avatar
problem with car
I am having a problem with my car. Im turning it back to stock so i can start my build but trying to get all the kinks worked out first. I have a CEL p0102. If i free rev the car it wont go past 4500. Also when i drive it it wont go past 4500. Car has UTEC, DTEC-BC, 272 cams, buschur mas pipe, and cat-back exhuast on it still. anyone have any ideas whats wrong.
ERIK
Old May 30, 2006 | 10:30 PM
anyone?
Old May 30, 2006 | 10:38 PM
SiCKlEyWiKeD's Avatar
my guess is that it's the utec, just a guess
Old May 30, 2006 | 10:42 PM
Evo_SpeedKing's Avatar
+1
Old May 31, 2006 | 09:14 AM
Kryptonite's Avatar
P0102 mass air flow sensor fault?
Old May 31, 2006 | 09:37 AM
djtmotorsports's Avatar
Either the UTEC crapped out or you have a broken wire (or two) in the harness between the car and the UTEC.
Darin
Old May 31, 2006 | 03:58 PM
pulled the UTEC outnd still had the same problem.
I put in a new MAS today. well see if it works!!
Old May 31, 2006 | 04:38 PM
1 Fast VIII's Avatar
I'd say it has something to do with the MAF... if u tapped into any of the wiring Check to make sure all the wiring is secure
Old May 31, 2006 | 04:59 PM
Ralph's Avatar
Is the car hitting a "rev limiter" at 4500?
Old May 31, 2006 | 10:05 PM
correct.
I put about 20 miles on it with the new MAF and so far so good. Ill be doing about 200 miles tomorrow so I'll know for sure if that fixed it.
ERIK
Old Jun 1, 2006 | 09:17 AM
Ralph's Avatar
According to that CEL i'd say its the MAF.. causing your grief
Old Jun 1, 2006 | 09:53 AM
evozakk's Avatar
DTC P0102: Volume Airflow Circuit Low Input
