Daily Driver GT35r
Old Jun 3, 2006 | 05:05 PM
MANGOOK's Avatar
Daily Driver GT35r
hey guys I am just curious how you think an evo would be with a 35r as a daily driver. The only member I saw with a really great right up has been ("Invoice Evo") Can anyone else give some info on if this would be a good move or if I am asking for trouble. I would want to run this set-up on 93 octane only at 20-22psi.
Thanks for your help.
Chris
Old Jun 3, 2006 | 05:07 PM
WrX Kila's Avatar
I guess you can do it. 22psi is worthless on a 35r... after 26psi and up is where these turbo shine.
Old Jun 3, 2006 | 05:14 PM
Rollaway's Avatar
You can daily drive it at 23psi.. with the right tuning and suporting mods you can get 450whp on pump no alky(yes it can be done and has been done a few times) ... The GT35R as a daily driver would not be a waste if setup correctly
Old Jun 3, 2006 | 05:15 PM
Blue Evo 8's Avatar
For a street car I wouldnt do a GT35R w/o the 2.3L bottom end.... if you go all out drag then sure go with either a built 2.0L or a built 2.3L
I'd suggest a 50 Trim for a stock bottom end for a daily driver...
Old Jun 3, 2006 | 05:18 PM
WrX Kila's Avatar
Must have been modded out the ying yang... including a stand alone.
Rez90's Avatar
if you are looking for a daily driver that you are definately never going to throw Meth or Race gas at, i would highly reccommend a 50 trim turbo.
On pump gas at 22 psi i made 430whp with better spool and response than a 35r with my turbotrix 50 trim.
If you're going to use meth or race gas, the 35r is the way to go.......but if you're set on only pump gas........50 trim all day long........IMO
Old Jun 3, 2006 | 05:23 PM
Rollaway's Avatar
Actually I didnt have much mods at all... I made 444.4whp on pump and with AEM I made 450.. the 444 was done with Denso 660 injectors.. both on 93, 23psi and NO ALKY
Old Jun 3, 2006 | 09:55 PM
marcmags's Avatar
how about ATP 3071?is it same as the 50trim?
Old Jun 3, 2006 | 11:56 PM
levo2nr's Avatar
a gt35r?
what mods did u have on the car, when u made 450 with aem ?
Old Jun 4, 2006 | 05:39 AM
Blue03Evo's Avatar
I have a daily driver 35r and i am putting out 440 on pump gas at 22psi. I do have alot of supporting mods though. I have yet to have a problem out of it
Old Jun 4, 2006 | 06:00 AM
MANGOOK's Avatar
If you dont mind what is your mod list?
Thanks
Old Jun 4, 2006 | 06:32 AM
Derek888's Avatar
Originally Posted by levo2nr
a gt35r?
how much boost you running?
Old Jun 4, 2006 | 06:35 AM
levo2nr's Avatar
im running 22-23 psi but im in the middle of putting in my alky
Old Jun 4, 2006 | 07:29 AM
sleet's Avatar
DO IT! Hopefully my time will come soon, although I hope AMS will have 37Rs by then, if not 35R ;/
Old Jun 4, 2006 | 10:03 AM
Blue03Evo's Avatar
Thanks
PM sent.
