Whats with my Evo!?!?
Old Jun 8, 2006 | 11:31 AM
CGs's Avatar
CGs
Whine "like a supercharger" -- I bet the front of your air intake is coming up, and the suction is causing the whistle as it touches the top of your hood. It'd be worth checking out
That's assuming you have the stock airbox
Old Jun 8, 2006 | 11:34 AM
MonsterEVOO's Avatar
Il try to make this as simpel as possibal... I drive my car and when i build boost insted of hearing the turbo suck in air.. i hear a Very loud wine (alot like a supercharger im not saying a evo has a supercharger but it sounds like one) And do any of you know what it can be.
Old Jun 8, 2006 | 11:35 AM
No the hood was open.. And i have the Injen Intake with the Upper I C pipeing.... And yes i made sure all those Hoses where tight.
Old Jun 8, 2006 | 11:38 AM
SP00LIN's Avatar
It could be your fuel pump.
Old Jun 8, 2006 | 11:39 AM
WTF_LOL's Avatar
Thats basically the same description you gave before. What rpm do you start to notice it? any notice in performance? I know you said you dont have a boost gage but can you tell if you are loosing boost? Any white smoke? Is it as high of pitch as a turbo or a lower pitch like a supercharger? does the sound continue all the way through the RPM's? Have you done any upgrades or changes to your car latley?
Old Jun 8, 2006 | 11:43 AM
The Sound Only happens When i hit Boost... I havent checked for any smoke or loss in power.. cuz i havent given it any gas cuz im scared i might mess something up. i havent change anything in my car but the intake system
Old Jun 8, 2006 | 11:47 AM
WTF_LOL's Avatar
I think that is a good idea. I would not drive hard untill you figure it out if you really are concerned.
Did the problems start right when you changed the intatake? You are probably already aware but whith an intake the Turbo "whine" will be much more pronounced then with the stock factory box which is designed to be quiet
RenoEvo's Avatar
its probably that ghetto injen intake. put the stock airbox back in and see what happens. Running an open intake system on any evo untuned can give you a list of drivability problems.
Old Jun 8, 2006 | 11:51 AM
I've had the intake in for months. And didnt have any problems.
Old Jun 8, 2006 | 12:29 PM
Danny23's Avatar
if your only mod is the intake i would take it to the dealer
Old Jun 8, 2006 | 12:30 PM
evo1337's Avatar
I once had a starter that would stick and stay engaged to the flywheel and it sounded like a supercharger. Doubt its related to your problem
CRVdrftR05's Avatar
If it sounds like an automatic transmission sound *a lil whiny* it's normal. If its from the engine bay I have no clue. =\ record a video for us?
Old Jun 8, 2006 | 12:33 PM
WTF_LOL's Avatar
Could the problem be described as sounding kinda like a belt whine? Is it sound "Grinding" at all? Metal on Metal?
Old Jun 8, 2006 | 12:55 PM
No metal to metal grinding sound.. alot like a belt wineing.
Old Jun 8, 2006 | 01:10 PM
Wheelhaus's Avatar
Process of elimination, son.
If you can repeat the sound when the car is at a standstill then it has absolutely nothing at all to do with the drivetrain (TC).
If you can repeat the sound as stated above (at standstill) then someone can poke and prod under the hood to see if the source can be found.
the supercharger sound you're talking about, its a mechanical whining correct?
does it happen ONLY in boost of any level or is it combined with going beyond a certain RPM? if it occurs in boost ONLY at any RPM, then it likely has to do with the turbo/intake tract. if it's RPM dependant, then it's likely something mechanical (belt or something that spins with engine RPM).
I've never experienced a dying turbo, but could it be the source of the noise?
