Bass - Rattles ???
Old Jun 16, 2006 | 06:17 AM
Oracle1's Avatar
Bass - Rattles ???
I have a 12" sub (sealed box) in the boot and the whole underneath boot area rattles alot from outside the car and also the back bumper too. What can I do to stop the rattling occuring other than to remove the sub, which is being played low. I just want some clarity sound but without the horrible rattles from the outside. The bass cannot be heard from the outside except the rattling.
Please advise how to get rid of the rattling???
Cheers!
Oracle
Old Jun 16, 2006 | 06:24 AM
kmcconn9's Avatar
some dynomat or other sound suppression material applied to the areas where the noise is coming from will help to suppress it.
It may not completly take it away, but it will help keep the road noise out, reduce/stop vibrations, and keep the music in the car....
Old Jun 16, 2006 | 06:29 AM
adamhw's Avatar
the most rattling I got was from the license plate. Dynomated it, now it's 10x better.
Old Jun 16, 2006 | 06:33 AM
daved's Avatar
take the sub out.
Old Jun 16, 2006 | 07:07 AM
kmcconn9's Avatar
/\ haha, there is one solution. But if you match the right sub with the right enclosure and make sure your license plate is secure, then you shouldnt have any rattles.
I have a cf trunk with a 8" polk momo sub in a custom enclusre made from the stock infinity enclosure (I will post pics up on this later) without any vibrations/rattles and the total package is less than 10 lbs...
Old Jun 17, 2006 | 03:27 AM
Oracle1's Avatar
Originally Posted by daved
take the sub out.
HaHaa There's always one!
So, dynamating the inside trunk should cure the rattles. Will the dynamat stop the back bumper from rattling too when applied on the inside trunk? Or do I need to do to something else to the rear bumper?
Old Jun 17, 2006 | 04:29 AM
matt55's Avatar
take the sub out.
Here is a idea i had , put the sound in the cab not the trunk , i see a lot of box bilt as tall and wide as they can be to fit in between the fender wells/under the read deck lid . Then you have your sub firing into your trunk witch is all most 100% sealed off due to a big box so the bass is pounding in you trunk , trunk is rattleing like h3ll and you now have a getto evo . Here is some pics of what i did to over come this ...
http://img336.imageshack.us/img336/700/dsc055318fk.jpg
http://img336.imageshack.us/img336/269/dsc055386av.jpg
With this set up i have had NO trunk rattles at all , I did one day trun the box around facing the rear just to see what it would sound like and it sounded like 100% a$s , like a freaking jackhammer was beting on my trunk . So the only rattle i have had while facing the sub forward is the dash(front dash)
Old Jun 17, 2006 | 05:37 AM
kmcconn9's Avatar
probably not because it is your bumper clips that are more than likley rattling..not the bumper itself. But you could try dynomatting that surface and it will help deaden the vibrations...
Old Jun 17, 2006 | 06:27 AM
ShiftySVT's Avatar
Could it be the flapper vents inside that little compartment on the left side of the trunk? I hear those rattle everytime I shut a door with the windows up.
Old Jun 17, 2006 | 06:39 AM
suprabanker's Avatar
I have 2 10" subs in a ported box, and it's just the rear license plate frame that rattles. It might be the rear license plate instead of the whole rear bumper for the vibrations. +1 for Dynomat, works great even though i'm currently not using any.
Old Jun 17, 2006 | 06:41 AM
gsrboi80's Avatar
I want one of thoose nets. Im sick of crap rolling around back there
Old Jun 17, 2006 | 07:41 AM
ZMYEVORICK's Avatar
take the sub out.
i agree with him, i had 2 12's in my trunk for a while i finally got sick of all the new noises i was hearing. but if u want them in there, some dynomatting should do the trick
chubsgts
Apr 4, 2012 12:40 PM
tilf_hunter
25
Sep 25, 2008 03:30 PM
bluewaterDEMON
Lancer Troubleshooting
12
Aug 27, 2007 07:43 PM
Illl
34
Jul 15, 2007 06:03 PM
Reboot
11
Feb 27, 2004 11:58 AM
