Damn, I just got the Walbro whine...
Old Jun 16, 2006 | 11:51 AM
nrcooled's Avatar
It whines but it's not that big of a deal. This is assuming you can hear it over the road noise of the tires, the whine of the x-case, or the banging of the dual springs in my valve train.
Meh, deal with it.
Old Jun 16, 2006 | 11:52 AM
GPTourer's Avatar
Originally Posted by Rmhaffa04
does it pause for a second if you hit the window switch?
example: all the windows are up, and you hit up on the switch, does it pause and then continue......
It might. All that stuff affects voltage. I don't have one on my Evo yet, but on my DSMs, the headlights, the A/C, the wipers - all would have some effect on the sound or tone or pulse.
Old Jun 16, 2006 | 11:56 AM
Rmhaffa04's Avatar
I have a whine and im pretty sure its the Walbro, i was just trying to make sure thats what it is.....
THANKS!
Old Jun 16, 2006 | 11:57 AM
Rmhaffa04's Avatar
Besides I only hear it when my radio's Off.......Mine must not be that loud.....
Old Jun 16, 2006 | 12:00 PM
RREvo's Avatar
Mine walbro wines sometimes, I don’t know why its happening.
Old Jun 16, 2006 | 12:02 PM
nrcooled's Avatar
Things that cause the walbro to whine:
1. Low fuel
2. Hard driving
3. Very hot weather
All of these are triggers for my walbro to whine.
Old Jun 16, 2006 | 12:07 PM
kimletrim's Avatar
Registered User
Whining Walbro...get over it. There could be worse things such as transfer case whine, whining passenger, etc.
Old Jun 16, 2006 | 12:11 PM
AC556k's Avatar
1. Low fuel
2. Hard driving
3. Very hot weather
My fuel check light was on
I live in Florida where it is 80+ when you wake up
I was running late to the office and hauling a$$
Point well taken
Old Jun 16, 2006 | 12:13 PM
RogueSTi's Avatar
Originally Posted by AC556k
This morning on the way to work the Walbro 255 fuel pump started the infamous whine I have read about. It sounds like a UFO is hovering under my back seat . Does anyone know what causes this .
Mine has been whining off and on for 1 1/2 years now. Dont worry about it.
Old Jun 16, 2006 | 12:24 PM
machron1's Avatar
I thought maybe the acoustics of the Evo were different because my Walbro wasn't whining like my DSM. 1 month later and it whines sometimes. Rolling up/down the windows makes it change to a lower pitch. I only hear it when I'm idling. I don't think there is anything you can do about it. In my eclipse I tried putting dynamat over the pump, but that didn't work because I think it is using the acoustics of the whole gas tank. You would probably have to cover the whole tank in dynamat along with the protrusion into the body. Not worth it as it's not really that annoying to me.
Old Jun 16, 2006 | 12:37 PM
Talon's Avatar
The one in my Eclipse is pretty loud, especially when I get get off the freeway or something. It's funny because I hear different tone when I turn on my turn-signal or something. Doesn't bother me, though.
I don't hear the one in the Evo so much.
Old Jun 16, 2006 | 12:44 PM
Her GSX's Avatar
Registered User
It "pauses" because you're pulling power away from the pump when using something electrical. It probably also does it when you use your blinkers.
DSMers use stock Supra TT fuel pumps. They flow around 255 also and are quiet, plus you have that oem Toyota reliability on top of that. I'd assume Evo's would be able to make them work as well.
Old Jun 16, 2006 | 01:08 PM
lancealott's Avatar
1. Low fuel
2. Hard driving
3. Very hot weather
Very well said. I actually think it sounds cool. I have no problem with my car being loud. Otherwise I would have stuck with the IS300 I had before this.
Old Jun 16, 2006 | 01:13 PM
Jaylenospoolboy's Avatar
Mine started whining after a year. It doesn't whine now that it's been replaced.
Funny, it started making a lot of noise on a hot day.
I've heard there are a couple of versions of the 255 lph. I wonder if that's why some whine and some don't.
Old Jun 16, 2006 | 01:41 PM
Darwinian's Avatar
Will a pressure regulator help with noise? I am planning to get one, but not if the whine is annoying.
