For those of you that think grounding kits are worthless...
Old Aug 12, 2006 | 01:33 PM
barneyb's Avatar
I'm still in the worthless group.
Old Aug 12, 2006 | 01:42 PM
Lancer EVO IX's Avatar
i'm selling the genuine mitsubishi grounding kit made by sun auto (the people who practically invented the grounding kit) for $100. here's a link to my thread. pm me if any of u guys are interested. this kit has specific grounding pts.
https://www.evolutionm.net/forums/sh...d.php?t=214745
Old Aug 12, 2006 | 02:07 PM
Evo_Jay's Avatar
Originally Posted by redevo8driver
not me when I did mine I didnt notice anything especially when my ac is on it still bogs the engine down maybe I didnt connect to everything I needed to I also made my own using 8 gauge wire and gold ring terminals.
Its because just using a grounding kit is only part of it. Go to the link I posted, do the Big/magic 3 and your electrical system will be a lot better, for sure. All the audio junkie do this and this is how to cure weak electrical systems.
Old Aug 12, 2006 | 03:17 PM
EvoTio's Avatar
I read your link to the Big 3 and it was very interesting. I've known about the larger gauge cable to the block and chassis, but didn't think about the wire to the alternator. What size fuse did you use for your alternator to battery cable set up?
Old Aug 12, 2006 | 05:23 PM
Evo_Jay's Avatar
I have yet to do my alt, power wire. I have did the alt. ground and the battery ground. I was going to use a 120A or 150A fuse. Most people on that board were using a fuse rated a little higher then their stock alt. fuse.
Old Aug 12, 2006 | 10:19 PM
barneyb's Avatar
Okay, I can see the need for this if you plan to install a big thumping audio system.
Old Aug 12, 2006 | 10:40 PM
Evo_Jay's Avatar
Yeah, its basiclly for problems that stem from stereos, but even if you didnt have a audio system then it would still make you electrical system more stable and stronger.
And that probably make a really consistent spark and a great ground, which (according to ground kit manufactures) makes power.
Old Aug 12, 2006 | 10:49 PM
barneyb's Avatar
Yeah, and keeps you lights from blinking to the music.
Old Aug 12, 2006 | 10:59 PM
jbrennen's Avatar
And all of the electrical modifications in the world won't change that. The A/C compressor doesn't run on electricity, it's driven mechanically by the engine.
Old Aug 13, 2006 | 04:47 AM
Ph3n1x's Avatar
True but the alternator when under excess load causes a loss in idle which then strains the AC and other parts on the drive belt.
LeXcite
Jan 17, 2022 08:05 PM
llDemonll
Sep 22, 2021 05:43 PM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
kd5byb
Sep 7, 2013 05:44 AM
